Funny whining sound - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-20-2006, 03:20 PM   #1 (permalink)
Funny whining sound
When I start my truck up, there is a whining sound that starts out low pitched and as the truck warms up, the pitch gets higher and then slowly goes away after about ten minutes. It sounds like its coming from the passenger side, but I don't know from what component (that sounds technical !). I have a 22re with about 115,000 on it.
Anybody got any ideas? http://www.yotatech.com/newthread.ph...wthread&f=116#
drink
goose234 is offline
Old 03-20-2006, 08:29 PM   #2 (permalink)
Elvota's Avatar
Although "funny whining sound" is very specifc, you may need to clarify a bit more.
You might be able to get closer to the cause by listening with a long screwdriver or better yet stethescope (spelling?) from your local auto shop. You can pin point sounds better that way.
Hope this helps point you in the right direction.
__________________
1990 4Runner | V6 3.4 | 5spd | 240 someoddthousand miles | SR5 | SAS | RLS | 35's | ARB | TJM | 217 to 1 | W8000
- four wheels | three sticks | two hands | one trail -
visit the sticki chronicles
Elvota is offline
Old 03-20-2006, 08:53 PM   #3 (permalink)
wjwerdna's Avatar
Send a message via AIM to wjwerdna
if you kick it hard enough and yell, it should stop being funny, but it may still whine, if that is the case, its better to just ignore it
but on a serious note, just a guess, check pumps, anything that spins with a belt....
heres a real simple check, that anyone should do just because, check belt conditions and tensions.... sorry i dont have the specs, check haynes manual.... 12.99 keep us updated
__________________
Andrew J W = WJwerdnA '99 4Runner SR5
- Pioneer MP3/IPod w/Infinity all around - lifted 2.5-3in susp. - 33's to fill the gap - sliders - ISR & Deckplate, yada yada - Satoshi -
AIM:wjwerdna
YotaTech Profile Custom Bumper Link
for sale:
??? Nothing?
wjwerdna is offline
Old 03-21-2006, 05:04 AM   #4 (permalink)
Flash319's Avatar
Power steering pump. Mine does it to. When it is really cold it is worse. Mine has been doing it for years with no problems. Maybe try changing the fluid. I was running auto tranny fluid in mine.
Flash319 is offline
Old 03-21-2006, 05:17 AM   #5 (permalink)
calg3's Avatar
Well, is it a whirring sound or a whining sound? Whining could be belts, whirring could be your fan clutch.
__________________
2006 Subaru Outback, miss my 4Runner!
2006 Mazda3, zoom, zoom...
Look at my previous truck(s) in the Yotatech gallery:
http://yotatech.com/showthread.php?t=42494
calg3 is offline
Old 03-21-2006, 05:20 AM   #6 (permalink)
It's a cold belt rubbing on a cold pully. Once both get hot, the belt warms up and (sticks) to it better so it don't yell. The inside of the belt will get a glaze to it and the problem will get worse (louder). I would check into it cause if it's the alt belt.....that's not good.
8422r4Runner is offline
Old 03-21-2006, 10:02 AM   #7 (permalink)
really depends on the sound. i, like flash319, have a whine coming from my power steering pump. to tell if its the belts, or the pump itself, get some belt dressing, or wd40 works in a pinch to, and when you first start the truck on a cold day, pop the hood, hit all the belts with a little spray(on the contact side) and if its belts, that will make it go away temporarily. if the whine is still there, im thinking about 95% sure its your power steering pump.
motoracer47 is offline
Old 03-21-2006, 10:12 AM   #8 (permalink)
Buck01's Avatar
I have a whine coming from the passenger side too....
but it's my wife!!! Still haven't figured out how to get rid of the problem yet : P
__________________
94 Toyota Truck 4x4 22RE, 5 Speed 175,000
MOD's include High performance Head with bigger valves and cam, LC engineering Header and complete exhaust kit.
I have upgraded headlights with the wiring harrness and Hella H4 allweather bulbs.
lift shackels in the rear
3 inch BL
Buck01 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
whining sound coming through speakers. ThomasJ 86-95 Trucks & 4Runners 9 12-17-2005 06:54 AM
Whining sound cccp Maintenance & Repair Archives 15 10-16-2005 03:13 AM
Whining sound from engine GreenRunner 95.5-2004 Tacomas & 96-2002 4Runners 3 12-20-2004 11:03 AM
help! funny noises don't sound so good sometimes :( alanbobalan Offroad Tech 0 10-15-2004 10:58 AM
2009 InternetBrands, Inc.
