fuel tank needs cleaning
i hear E85 gas will work pretty well
seriously, don't put E85 in your truck. it'll do bad things to your pump and seals. Eastwood company sells a gas tank kit, as does POR-15.
POR15 actually makes a tank liner which is supposed to be a lot better than Kreem...?
the machine shop I use will put gas tanks into the same tank that they boil the engine blocks in... does get rid of the rust but will get the varnish and sludge.
if you're looking to get rid of the rust/varnish permanantly i'd get the por-15 gas tank kit thingy. rust is gunna be hard to get out, but por-15 is good at covering up rust, and creates a layer that will not rust through. the varnish you can probably get out with various solvents.
skoti89
09-11-2015 07:46 AM
pyramid
07-30-2015 10:05 AM
TURBOrunnerNM
07-22-2015 11:01 AM
