Fuel Tank Flex Line Feed Fitting 14mm x 1.5
Old 06-09-2007, 07:27 PM
ewong's Avatar
There are Pics on Pirate 4x4 under the Quasimodo Project
http://www.pirate4x4.com/forum/showt...&page=16&pp=25
The EFI tank on a 22RE has a shor flex line between the top of the tank outlet and the hard line on the frame rail.
Its not uncommon for the fuel line to "rot"
Im considering using AN lines (i.e. -6 teflon lined AN lines or rubber)
There is an adapter -
9894DBHERL
Its designed to accept a 14mmx1.5 male thread - but its also desinged for an "O" ring on the tip of the male part.
The question - does the OEM Toyota Tank feed have the O ring on the tip?
In other words - if I install this fitting - will the dang thing LEAK?
Eggslinger
06-08-2019 03:32 PM
Doug4320
03-24-2018 10:11 PM
09-04-2015 09:27 AM
TURBOrunnerNM
07-22-2015 11:01 AM
skoti89
07-08-2015 12:05 AM
Quick Reply: Fuel Tank Flex Line Feed Fitting 14mm x 1.5
