Fuel pump wire?
Fuel pump wire?
Have a 95 runner , harness is damaged under the hood from a small fire. , need to run the fuel pump to empty the tank.
I tried the one on the diagnostic connector on the fusebox under the hood, no workee.
Any easy way to put power on the wire that goes to the pump?
Any easy way to access that wire?
Getting a mechanical pumped diesel conversion.
Is there another place I can grab the fuel pump wire?
Or is there a relay between the engine compartment and the pump?
oh yeah running the fuel pump is't gonna get all the fuel out either. Not sure why you want the fuel out though. So it doesn't gum up the tank? If so drain it using the drain plug.
Need to drop the tank & remove or bypass the pump , as the 1kzt doesnt need it. Be cool to bypass the pump and use a checkvalve so I could switch on the electric pump to prime the diesel injection pump
if your switching over to diesel then I would definitely just use the drain plug, I am fairly certain all the the toyotas had them. But I believe you will have to take the skid off. Not sure where exactly they are located though.
yea but then anyone can come up and pull your drain plug and steal your gas or at very least leave you stranded and without fuel
to answer your first question on other searching later, if you find the relay high up in the passenger kick panel, unplug it and then apply 12+ to the blue wire that will kick on the fuel pump.
09-04-2015 09:27 AM
TURBOrunnerNM
07-22-2015 11:01 AM
