Fuel Pump remplacment
Old 08-26-2009, 02:06 PM
mac9968's Avatar
Hello all, I have been trouble shooting an issue that pointed to my fuel pump. I have dropped the tank to find that the pipes to the tank, and pump are in bad bad shape. I placed my wrenchs on to break the fittings, and several leaks started i the hardline. I also crimped my fuelpump input on the top of the pump (external to the tank). I am now left with a fuel line that leaks.
The question, has anyone every replace a section of thier hardline with highpresure rubber, and if you did any lessons that you can share. I am going to buy a pump (Orig problem) and now a frame for the pump, plus the secion of hose if that makes sense.
I feel like a heal, but the fuelline was going to fail me at some point i guess
Old 08-26-2009, 06:59 PM
bugs1961's Avatar
You can order a new hard fuel line from Toyota. I would personally not do it, but if you're going to use a rubber hose get fuel injection hose and not standard fuel hose due to the higher fuel pressure. You can get the part number for the OEM pipe here: http://www.toyodiy.com/parts/
Old 08-26-2009, 09:00 PM
24Runna's Avatar
Rubber high pressure fuel injection hose is the best.
If it only in one small area, a really cheap fix is QuickSteel epoxy, fixed my leak instantly.
Old 08-28-2009, 12:41 PM
mac9968's Avatar
Excellent, thanks all. I went the Rubber fuel injection hose route.
sandyota
02-04-2021 11:16 AM
09-04-2015 09:27 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Fundy Rider
07-16-2015 01:35 AM
Tyler Cunningham
07-11-2015 10:18 AM
Quick Reply: Fuel Pump remplacment
