Fuel pump gasket
Old 01-04-2011, 08:06 PM
Catamount's Avatar
Question Fuel pump gasket
I can't find a replacement fuel pump gasket or will take days to order but need to finish ASAP. Can any one suggest a gasket forming sealant (FIPG)? I also need an alternative gasket for the drain bolt. Didn't have one when I opened it.
Old 01-04-2011, 08:26 PM
Catamount's Avatar
its a 3vze
Old 01-05-2011, 06:51 AM
swampfox's Avatar
You can make gasket out of a piece of card board . I have used a cereal box more than once to make gaskets.
Old 01-05-2011, 07:31 AM
diablo's Avatar
The fuel pump gasket is like rubber go to the parts house and find rubber or gasket material and make a pattern, the drain plug also
Old 01-05-2011, 08:17 AM
Catamount's Avatar
I have a variety pack of gasket material. Was waiting to see what original material is used once tank is apart. It's tedious but may have to make own. Would trust better if I used a gas safe tack sealant. Any suggestions?
Was hoping to find FIPG.....easier and quicker, I'm working under relatively harsh conditions.
Research so far, all FIPG manufacturers info say do not use in contact with gasoline especially silicone based!
Old 01-05-2011, 09:38 AM
Catamount's Avatar
Hey I stumbled onto another thread specifically about FIPG /RTv s. "What Seal Packing (gasket material) do you prefer". Permatex has three products mentioned including hylomar that are ok with gasoline.
Thanx everyone I'm back to working instead of surfing.
SwampFox... been there done that. reminds me of days living in Africa where ingenuity and brawn meant survival. No Auto Zone down the road.
Old 01-05-2011, 10:07 AM
swampfox's Avatar
missed the part about it being a 3vze ,I was thinking 22r.
smthwsn357
12-04-2023 02:08 AM
sandyota
02-04-2021 11:16 AM
09-04-2015 09:27 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Tyler Cunningham
07-11-2015 10:18 AM
Quick Reply: Fuel pump gasket
