Fuel Pump Compatibility
Old 08-30-2010, 09:16 PM
forbiddenera's Avatar
'89 4Runner into a '90 Truck..
Just spent 2 hrs trying to get the tank off the 4Runner when I find the access panel to the pump on top.. YES I did look first.....just in the wrong spot..
Anyway, pumps compatible? If so I now own a '90 ext cab 4x4 w/3" lift + 31" tires ..?
Old 08-30-2010, 09:20 PM
Quick google reveals ac delco oem replacement parts for both models is same part number.
I should be fine..woo..
Old 08-30-2010, 09:24 PM
ARRC says to remove the tank so I'm not the only dummy..
Old 08-31-2010, 03:20 PM
Hadmatt54's Avatar
I see that you are swaping in a 5m-ge. Use the 5m-ge pump and filter screen, it's a little bit bigger around but it fits the pump bracket in the 4 Runner tank perfectly!
That's what I did, it was the pump off of an 88 Cressida, that my 5m came out of!
Old 08-31-2010, 05:04 PM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
RE's are RE's...
But Turbo's are V6's...
I'd pony up for an OEM if I had the money... But suspect Bosch is OEM. IIRC, the EFI system is Bosch.
Old 08-31-2010, 05:15 PM
myyota's Avatar
Originally Posted by tried4x2signN
RE's are RE's...
Bosch is NOT oem, Denso is oem on our truck, and our EFI system is not bosch either. They are not the same in any way.
Old 08-31-2010, 05:17 PM
myyota's Avatar
Does the 5m-ge fuel pump put out more presure than a 22RE fuel pump ?.
Old 09-01-2010, 01:05 PM
Hadmatt54's Avatar
I never measured the pressure on a 22re pump versus a 5m pump. Listed fuel pressure on a 22-re is 33-38 psi, on a 5m it is 36-38 psi. Pressure is really not revelant. 22re's have a pressure regulator on the end of the fuel rail and a return line back to the tank. The regulator will control the pressure in the system, however if you are talking about volume then due to the larger size the 5m pump would provide more fuel at the same pressure. the 5m pump is after all built to run a 6 cylinder engine while the stock 22 re pump is only for a 4. So at the same pressure the 5m pump must supply fuel to two more injectors, thus more volume. if you are doing an engine conversion then I'd match the pump with the engine.
Old 09-01-2010, 01:12 PM
xxxtreme22r's Avatar
sandyota
02-04-2021 11:16 AM
09-04-2015 09:27 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Fundy Rider
07-16-2015 01:35 AM
Tyler Cunningham
07-11-2015 10:18 AM
Quick Reply: Fuel Pump Compatibility
