Fuel problem no start help please
Old 02-08-2010, 05:14 AM
YoterUp's Avatar
Ok this is what happend. I was driving down a bumpy road and the truck just shut off. we got out looked around and we figured out it wasnt getting fuel so we kicked the tank about 6 times and the truck briefly started back up again so we figured it was a fuel pump we took the bed off and on the top of the tank the power and ground were barly attached and rusted so i pulled the pump housing out and it was really clean and nice looking(about the only thing on the truck that does) so we hard wired the pump to the battery and it works perfect every time so we cleaned it up re mounted the power and ground onto the the pump and put it back in and hooked it back up and i get nothing. i ran a hard power from the battery and the pump worked and pumped fuel after so i figured it was a relay so i went abd bought a new one and i still got nothing and even with the pump hard wired the truck wont start and im not getting any gas back on my return but it has plenty of pressure at the fuel lines. anyone have any ideas?
Old 02-08-2010, 07:19 AM
YoterUp's Avatar
Bump need help please
Old 02-08-2010, 07:46 AM
Chuck Manners's Avatar
did u check to see if u were gettin any spark from the plugs?
Old 02-08-2010, 08:16 AM
YoterUp's Avatar
no i didnt. im going to check after class today. i also have a 3.0 v6
Old 02-08-2010, 08:34 AM
another thing would be make sure all your fuses are in good shape mainly the ones for your ignition. i had a simular problem one time when i got some water in the computer i just pulled it apart snd dried it out and plugged it back in and its worked fine since
Old 02-08-2010, 10:03 AM
YoterUp's Avatar
ill take a look thank you
Old 02-08-2010, 10:33 AM
4Crawler's Avatar
Try the fuel pump test jumper:
http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
bigblue82
10
07-06-2015 08:27 AM
MadMax48
07-03-2015 08:26 AM
rbravo1
06-29-2015 01:34 PM
jmc88runner
06-18-2015 03:39 PM
Dennis140
06-17-2015 10:37 AM
Quick Reply: Fuel problem no start help please
