Fuel pressure deops when accelerating
Old 03-09-2014, 02:13 PM
Badplasma's Avatar
I have a 90 4runner V6 m/t.. Did a fuel pressure test today and when it's idleing the fuel pressure is between 37-39 psi.. But as I slow increase the throttle up around 2500 rpms the fuel pressure would start to drop to zero and then die.. Any thoughts?
Old 03-09-2014, 02:46 PM
wyoming9's Avatar
Red face
Could be a few things.
China built fuel pressure gauge??
Will the engine idle as long as you want??
As the pressure drops the engine stalls
Fuel filter blocked the pump can`t push it through fast enough.
Your circuit opening relay is dropping out and the pump shuts off
The pump sock is full of rust so it can`t keep up with demand
the pump is on it`s last breath before it dies.
Old 03-09-2014, 03:00 PM
Badplasma's Avatar
While fiddling with a few things today I'm not 100% sure but seems to run better when vafm is messed with.. It's got a new fuel filter..
Old 03-11-2014, 12:04 AM
wyoming9's Avatar
Red face
If for some reason The AFM is not adjusted correct or getting old or tired it will cause the fuel pump to shut off.
Could just be a poor or corroded connection could be some foreign object blocking the door .
Things do wear out our trucks are no longer new.
jbv808
08-06-2021 04:47 PM
Doug4320
03-24-2018 10:11 PM
Poppie51
07-23-2015 05:03 PM
v_man
07-23-2015 04:01 PM
Poppie51
07-16-2015 06:16 PM
Quick Reply: Fuel pressure deops when accelerating
