Fuel Line Replacement
Steel vs. Rubber Fuel Line
Quick Question
Is our fuel sysyem high or low pressure? Broke one of the steel hard fuel lines from the tank to the filter. Just wondering if I can just replace whole thing with a flexible rubber line?
It is high pressure if you have fuel injection If yours is carbed it would be low pressure.
You can replace the steel line with fuel injection hose and clamps although the line is quite expensive.
Are you sure you didn`t break the line where it comes off the fuel pump bracket.
Hope that helps good luck
Avenged
07-09-2015 07:55 AM
Jnkml
07-06-2015 01:20 PM
