Fuel Issue on 92 Pickup
Old 08-14-2007, 04:30 PM
ETNRIDER's Avatar
First let me say hello, as this is my first post. I have been browsing this site for a little while and there seems to be a bunch of high quality people here with a lot of great information. Now to the good stuff?.
I have a 1992 Toyota Pickup, Automatic, 22re, 4x4. I recently rebuilt the 22re after my dad let it sit idle for about 3 years. The truck ran ruff when I brought it to my house to rebuild. I am now ready to start the truck, but my fuel pump is not pumping and I don?t think my injectors are putting fuel to the pistons. I have check the EFI relay and Fuse both are in working condition. I have also bypassed the wiring harness to hard wire the fuel pump and it did pump and I have fuel to the fuel and pressure at the fuel rail. I am stuck at the moment and I have no real other ideas what or where to check.
I am located in Knoxville, TN so if you are close and feel like giving a hand it would be greatly appreciated.
Thanks in advanced for any help
Old 08-15-2007, 08:34 AM
ETNRIDER's Avatar
Anyone have any ideas?
Old 08-15-2007, 09:14 AM
runethechamp's Avatar
Look here to see the whole curcuit that controls the fuel pump. There's a few more items you can check there.
http://personal.utulsa.edu/~nathan-b...28fuelpump.pdf
Old 08-15-2007, 12:19 PM
Innocent Fool's Avatar
Under the hood on the passenger?s side fender is the diagnostic box.
Open it up and place a jumper wire from the B+ to the Fp location.
You ?should? now hear the fuel pump running.
See if the truck will start.
This happened on my truck and this is how I fixed it. I just left the jumper in and drove it.
Give it a try and post your results
Good luck!
Old 08-15-2007, 03:31 PM
chopitrakeit's Avatar
Check the maf flapper in the air duct. If it sticks closed you get little air and zero fuel pump power. Something that sat that long could have the home of a rodent in the air box as well, I would clean out the air ducts from the boax to the throttle body.
Old 08-15-2007, 06:29 PM
ETNRIDER's Avatar
WOW!! Thanks for the replies!! I will try the jumper first thing when I get out to the garage. All the air ducts have been cleaned and I checked the flapper it was functioning.
Again, Thanks for your help!
Old 08-15-2007, 06:40 PM
ETNRIDER's Avatar
Good luck!
THE FUEL PUMP WORKED!!!!!! but it still didn't start !! I will check to see if the injectors are actually putting fuel in some time Thursday. The motor hit a lot harder so I know I am getting close.
Thanks Innocent Fool!!
Old 08-15-2007, 06:41 PM
ETNRIDER's Avatar
Where exactly is the MAF Flapper at in the air duct??
Old 08-16-2007, 03:12 AM
It is in the top cover for the airbox. its what tell the computer how much air flow there is and it needs to see air flow before starting the fuel pump.
Old 08-16-2007, 02:15 PM
ETNRIDER's Avatar
checked the flap, it is ok. I guess I need to check injectors next.
Old 08-16-2007, 02:36 PM
foot0069's Avatar
Checked the filter.Could be crapped up.
Jim
Old 08-16-2007, 02:43 PM
ETNRIDER's Avatar
The intake path is all new and clean. All the connectors are hooked up. Good idea though.
Old 08-16-2007, 02:58 PM
foot0069's Avatar
Thats good but i meant the fuel filter from sediment an goop in the tank.
Jim
Old 08-16-2007, 03:59 PM
ETNRIDER's Avatar
Jim
WOW my bad Rookie mistake!! I have a new fuel filter and it ran when I drove it over here about 4 weeks ago. I drained the tank as much as I could and it did not look too bad.
***UPDATE***
I pulled a plug to make sure I was still getting spark and I am but it is only sparking like every 2-3 seconds. I don't think that is normal. If it is not then I guess now I am dealing with a bad timing issue.
Thanks agian for all the help!!
Chris
Old 08-18-2007, 03:36 PM
ETNRIDER's Avatar
Still not getting fuel into the head. Timming looks ok my buddy said, he seemed to know what he was talking about.
puffin04
07-10-2015 09:17 PM
sonic concepts
07-01-2015 02:33 PM
saphirekosmos
06-22-2015 10:26 AM
bobbybouche
06-18-2015 10:22 AM
Quick Reply: Fuel Issue on 92 Pickup
