| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Fuel Injectors 92 4R
#2 (permalink) |
Are you sure you tightened the fuel rail bolts back up? Also those washers under the fuel rail banjo bolts are suppost to be replaced any time you remove them.
Got good insurance?
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. Last edited by mt_goat; 08-19-2006 at 11:44 AM. |
#3 (permalink) |
Staff
It must be an assembly/O-ring issue.......you can't get enough pressure to leak like that
__________________
David TLCA 14788 71 Landcruiser FJ-40 TBI 327, TH-350, Warn 8000, disk axle swap. 76 Landcruiser FJ-40 project/parts (haven't decided) |
#4 (permalink) |
orings from Ell
Yep had to disassemble it again - they said to put gas on the orings prior to insertion I did them dry -eek not good reassembled with new orings and added some lube- went in clean and no leaks this time.
thanks for the help J |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| fuel injectors for 92 4runner 3.0 V6 | alankenji_84 | The Classifieds GraveYard | 1 | 01-28-2007 03:49 PM |
| will parts from a 92 4R fit a 90? | christutecky | 86-95 Trucks & 4Runners | 2 | 03-27-2006 04:40 PM |
| Need spark plug numbers for '92 4R | FastCat | 86-95 Trucks & 4Runners | 7 | 01-08-2006 11:50 AM |
| 92 4R injector leaking. What do I need? | Nvision-Az | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 08-29-2005 02:23 PM |
| Aftermarket Fuel Injectors/Fuel Rails | Bumpin' Yota | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 03-17-2003 08:05 PM |
