Fuel injector R&R 3vze
Old 10-03-2010, 02:49 PM
skypilot's Avatar
Question Fuel injector R&R 3vze
I got the fuel injectors out. Off the witch hunters they go in the morning. Now how do you get the lower seals out?
Mine are hard and stuck. Maybe a lag screw to pull them?
Old 10-03-2010, 03:23 PM
MudHippy's Avatar
I'd grab 'em with a pair of vise-grips and try twisting and pulling on them at the same time. See if you can't wiggle them out that way. Or maybe try and pry them out with a big ol' screwdriver.
Old 10-03-2010, 04:23 PM
BigMac's Avatar
I used a hooked pick on mine.
Old 10-03-2010, 04:29 PM
TNRabbit's Avatar
Ditto--This works well~
Old 10-04-2010, 04:31 AM
skypilot's Avatar
Sounds like a plan; brute force. I hope none of it falls in!
Old 10-04-2010, 07:01 AM
skypilot's Avatar
Who sells these lower seals or are they called "grommets"? It looks like I broke them all.
Old 10-04-2010, 10:01 AM
MudHippy's Avatar
See this thread,. https://www.yotatech.com/forums/f116...rommet-219949/
Old 10-04-2010, 10:36 AM
Andy A's Avatar
Are you talking the black quarter sized pieces like the one's circled in red here
or the seal above it 23291???? If it is 23291 you should get them with your injectors when you get them back from servicing or witch hunter can supply them.
Old 10-04-2010, 11:00 AM
MudHippy's Avatar
Thumbs up
Thanks for that diagram. That clears things up a bit. Now I'll fix that other thread too...
INJECTOR INSULATOR 23291 [Part# 23291-41010]
SPACER [Part# 90561-10002]
O-RING [Part# 90301-23004]
Here's an online source for OEM parts.
http://1stToyotaParts.com
raptor510
02-17-2017 07:11 AM
RatOmeter
10-22-2015 03:17 PM
Tacoma1313
08-17-2015 05:44 PM
pyramid
07-30-2015 10:05 AM
HookahRoo
07-20-2015 07:06 PM
Quick Reply: Fuel injector R&R 3vze
