Fuel Injector Problem on 1994 3.0
Smelled strong gas smell. Found the source was the front injector on drivers side. It was actually causing a puddle of gas.
Replace O-ring in injector. Still smelled gas and still puddling.
Second O-ring kit. Still smelled gas and still puddling.
Replaced injector. Gas smell and puddling still a problem.
I've become quite proficient at removing the plenum.
What is next? Fuel rail a problem?
Did the full reseal. Found some bubbles coming from the replaced injector. Guess it was bad. Going to try again.... One more time.
Noticed the reman. injuctor had different seals than the one that came out had. The cushion ring rubber was too thick and wouldn't let the injector set in the insulator correctly. What is the part number for the correct kit? Is the o-ring kit pricey?
I know the leak is coming from the top because the whole injector is wet with fuel, even where the plug is.
Road Bull
10-10-2015 04:55 PM
steve miller
10-10-2015 01:40 AM
