Fuel Filter Location - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 11-09-2009, 01:44 PM   #1
I'm new so I'm sorry if I have asked a question already on an existing threat but I can't finger out how to search.
My question is where the bloody hell is the fuel filter on a '86 22RE. I'm in the middle of a lower end rebuild and I cannot remember where the fuel filter is located.
Can anyone help? A photo would be most helpful.
NHEngineer is offline   Reply With Quote
Old 11-09-2009, 01:48 PM   #2
right side of block!!!
awm3tm is offline   Reply With Quote
Old 11-09-2009, 01:51 PM   #3
Myron's Avatar
Hope this helps..Good Luck
Myron is offline   Reply With Quote
Old 11-09-2009, 02:22 PM   #4
Yup, I know it's on the right side but I can't find any holes on the block that will line up with the holes on the filter and still allow the 'out' line to attach to the 'out' fitting on the filter. My next quest will be to finger out why fuel leaks out of the bottom tube on the charcoal canister - but fuel filter first.
Old 11-09-2009, 02:26 PM   #5
Yeah fuel filter is a B@#%h to get to! does your truck run and leak fuel. My 87 4runner will not start, no power to the fuel pump relay checks out ough!
Old 11-09-2009, 02:58 PM   #6
cgeorge's Avatar
I'd replace it.. it is a pain in the a55 but worth it..
cgeorge is offline   Reply With Quote
Old 11-09-2009, 02:59 PM   #7
Fingered it out. I went back downstairs and looked at the pile of brackets and found one the does the trick. Now I feel so dumb but I guess there's no way to insert photos here so I can't provide data for the next guy. I was able to attach two photos but I don't know how to show them in the text.
By-the-way, it's an '86 4WD pick-up if that matters.
Old 11-09-2009, 03:04 PM   #8
Now the charcoal canister. It leaks fuel out of the bottom hose unless I loosen the gas cap. Someone told me it was because the canister is plugged but but I don't understand how that can happen. Any ideas?
Old 11-10-2009, 11:51 AM   #9
Nope, I printed your photo and checked the cannister. The hoses are correct. What is supposed to be attached to the hose barb nearest the firewall? Neither your nor mine have anything there.
Old 11-10-2009, 11:55 AM   #10
4Crawler's Avatar
Quote:
That is the Purge line and hooks to the P (purge) port on the throttle body:
http://www.4crawler.com/4x4/CheapTri...ne_Pix/19.html
Purpose of Purge line is to apply vacuum to the canister to draw gasoline fumes out of it. Might be your canister is shot if that purge line has been off too long, it may have become saturated with gasoline. FSM has clearing and testing procedures.
4Crawler is offline   Reply With Quote
Old 11-10-2009, 12:04 PM   #11
bob200587's Avatar
Quote:
Not hard to get to at all if you take the passenger wheel off, and the little access panel in the fender well off. Also makes replacing the starter a breeze too.
bob200587 is offline   Reply With Quote
Old 11-10-2009, 12:14 PM   #12
Nothing is attached there. The other end goes to engine vacuum then? Where? On the EFI housing somewhere? I wish your photo was a bit bigger.
Rough idle mystery Eggslinger 86-95 Trucks & 4Runners 17 01-18-2017 06:03 PM
Please help! smthwsn357 86-95 Trucks & 4Runners 7 04-11-2016 06:22 AM
1991 Pickup - 3VZE fuel line / filter stripped out. How to replace? pyramid 86-95 Trucks & 4Runners 10 07-30-2015 11:05 AM
NEED HELP!!!!!!!!!! 91 pickup 3vzfe Hiluxtrucha 86-95 Trucks & 4Runners 5 07-22-2015 11:00 AM
94 pickup fuel lines Fundy Rider 86-95 Trucks & 4Runners 4 07-16-2015 02:35 AM
Tags
1985, 2002, 22re, 24, 4runner, 91, access, fillter, filter, fuel, line, location, pump, purging, relay, toyota, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
