Fuel Filler Neck
Old 07-26-2014, 06:52 PM
BStrick1993's Avatar
Question Fuel Filler Neck
Hey guys, my fuel filler neck is pretty much corroded to the point of needing to go. I have been looking around and haven't found a new replacement for the pickup but I've found them for the 4Runner. Are they the same? Or, is my best bet to get a junkyard filler neck in the best condition possible?
Thanks
Old 07-26-2014, 07:07 PM
scope103's Avatar
a) Find the part you want: http://www.toyotapartsoverstock.com/...720135370.html
b) go to "fitment" of the part, and check that your vehicle is on it.
(The "filler" neck is in several parts, but I suspect you know which part you want. It seems to depend mostly on the length of the bed, not 4runner v. truck)
The new part is less than $100. It's up to you whether you want a dangerously explosive fluid protected by something reasonably called "junk."
Old 07-27-2014, 01:53 PM
You are the man! Thanks for the link. I'll be sure to follow through with this. I don't want to put a questionable used piece on unless there is no other alternative.
jashoeuh
11-26-2017 07:01 AM
mussy01
12-13-2016 08:20 PM
Team420
12-30-2015 01:31 PM
TJWilly
07-31-2015 02:05 PM
horunner1x
07-10-2015 06:33 AM
Quick Reply: Fuel Filler Neck
