fuel in crankcase/oil
Old 01-30-2013, 08:52 AM
Marvin Harry's Avatar
1987 toyota 22e starts for a second, floods cylinders with fuel, fills oil with fuel. Replace fuel pressure regulator with a new unit...still the same problem.
Please help...
Marv
Old 01-30-2013, 01:30 PM
Co_94_PU's Avatar
Please help...
Marv
Did you test that regulator before you replaced it?
Have you pulled inspected and tested the injectors?
How about the compression test?
Inspected the fuel return line to the gas tank?
Old 01-30-2013, 02:01 PM
HighLux's Avatar
Injector sticking open
Old 01-30-2013, 04:03 PM
three of the cylinders are flooded with fuel, a lot of fuel. Can a malfunctioning AFM create this problem?
Old 01-30-2013, 04:06 PM
HighLux's Avatar
Check the injectors
Old 01-30-2013, 05:17 PM
BamaYota1's Avatar
Injectors. Check all including cold start.
wafoogalla
11-02-2016 11:02 AM
daddio
08-09-2015 07:17 PM
Hiluxtrucha
07-22-2015 10:00 AM
Fundy Rider
07-16-2015 01:35 AM
shisha1999
07-13-2015 11:09 PM
Quick Reply: fuel in crankcase/oil
