Front skid plate tips and recomendations
I'm looking into getting a skid plate for my 95 4runner. I'm not trying to go rock crawling or anything so I don't need a full body one. Just one that will push mud and water rather than allowing a lot of water to go into my engine compartment.
My current skid is perf 14g aluminum. Ive got my cooler bolted to it.
Crappy shot. I have a 3/16 skid under the diff i sandwiched the tin with.
This is an area that beefier is better, thicker material needs less bracing.but if your set on thin. A couple 2x4s, c clamps and a mallet give good bends to 14g steel.
Fwiw my plan is to go 3/16 plate and do somthing about the cooler either e fan or manual swap
That is definitely something I will be able to do. I have a good family friend that owns a shop that might be able to do the bends for me, thanks for the tip!
If you can avoid it. My cooler is too big for behind the grill without ditching the ac so got shoved dowb there. It does work well though. No mud to clog it here in socal
Did we switch to pirate? It works for me. Its advice, i did rec a heavier plate. Some people manage to keep their rigs from falling into the holes you apparently cant avoid.
End of rant
End of rant
Wow, such hate. It's a 'skid plate' not an 'I just hit a rock at 20 and now it's toast plate'.
More realistically, it's an 'I have a big space under my bumper and I want to deflect air around the front suspension so I lose as little mileage as possible' plate.
One might actually be surprised how much weight 1/4" aluminum with 90* returns on the edges can support if it's not hit with sudden force.
06-01-2021 01:51 PM
BeMiceElf
10-10-2015 09:40 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
