front shocks keep getting mangled by chasis bumpstop
Old 03-08-2013, 12:41 PM
AZ94RUNNER's Avatar
Hey guys,
Here's the issue, I keep getting my front shocks all scarred up somehow. The keep getting deep gouges down them from the bump stop mount on the body. The 4 runner has a 4" super lift on it. I have those cheap ass bump stop extenders installed. I have ground down both the extenders and the chassis mounted stop. This will be the fourth time I have replaced the shocks these only lasted about 1 yr this time. My torsion are adjusted to the correct ride height and pretty much neutral. I'm at a loss as to what else could be causing this. Other than something is severely tweaked. Anyone else have this issue ? and if so what have you done to fix and or suppress it a little. Thanks.
Old 03-08-2013, 12:43 PM
snobdds's Avatar
Pictures go a long way here...Otherwise it's just a guess.
Old 03-08-2013, 12:47 PM
AZ94RUNNER's Avatar
Pictures will be uploaded as soon as its not pouring rain and snowing here. Any help untill then would be just that, help.
Old 03-08-2013, 02:53 PM
snobdds's Avatar
Ok...my guess is it's your bump stops.
Old 03-08-2013, 03:56 PM
BigBluePile's Avatar
Gonna need pics. I had this problem originally but once I ground down the mounts and took it to a frame alignment shop, it was good. Youll have to jack up the front and see where things droop. There's a really good write up on doing front end alignment as well. After a bracket lift goes on, you'll have to go to a frame alignment shop. The locally tire&wheel guys probably only adjusted the TRE's..... You have to actually adjust the lower a-arms.
Old 03-08-2013, 04:03 PM
Here:
https://www.yotatech.com/forums/f116...ite-up-163432/
Old 03-08-2013, 04:39 PM
AZ94RUNNER's Avatar
BigBluePile, thanks. The aligment has been done less than a month ago. and I've checked the droop. Im sure its something simple as setting things back a 1/4 of an inch...or I've just totally tweaked the entire system up there.
Old 03-08-2013, 04:47 PM
Hmmm.... well here is what I used. Wouldnt hurt to try
http://www.sdori.com/SDORI_4WD_Align...ions_Main.html
Old 03-08-2013, 05:23 PM
AZ94RUNNER's Avatar
as you can see in the third pic the is not much clearance?? BigBluePile I have the print out from the alignment I will check the specs with the sdori link thanks.
Old 03-08-2013, 05:28 PM
I cant see the pics for some reason :/
Old 03-08-2013, 05:35 PM
AZ94RUNNER's Avatar
pics
pics of the issue
Attached Thumbnails front shocks keep getting mangled by chasis bumpstop-p1040114.jpg   front shocks keep getting mangled by chasis bumpstop-p1040117.jpg   front shocks keep getting mangled by chasis bumpstop-p1040118.jpg
Old 03-08-2013, 06:08 PM
Geezus. Ya that's way too close
Youll need to grind more off I think...Definitely need to adjust those a-arms
Old 03-09-2013, 07:24 AM
snobdds's Avatar
I retract my guess of earlier due to visual evidence.
A-arms are totally off of the verticle plane. I don't think adjusting the a-arms could bring it in what you would need. Is the frame bent in any way?
Old 03-09-2013, 07:41 AM
j2the-e's Avatar
Wow. Looks like you either need to mount the shocks or the bumpstops somewhere else. Probably easier to move the bumpstops
Old 03-09-2013, 04:49 PM
Its not the bumpstops, its the a-arms......because that's where the shock mounts....to the lower a-arm...
Old 03-12-2013, 12:33 PM
AZ94RUNNER's Avatar
In terms of adjusting them out laterally I don't think the camber bolt has enough play. This rig hasn't been wheeled very hard since I have owned it. Willing to give it a try though. Obviously something is not rite. Just having a hard time figuring it out. Will let y'all know what the outcome is. Thanks.
Old 03-12-2013, 07:36 PM
The bolts should turn 360* to adjust the position of the arms.
Old 03-12-2013, 07:47 PM
j2the-e's Avatar
Looks to me like the bumpstop bracket is hitting the shock tube.
Re-locating them is a better option than throwing the alignment out of whack. You can't just start moving the control arms to wherever you want them and not expect other bad things to happen as a result. If the alignmet is set, and you are happy with the way it rides, and the tire wear, leave the control arrms alone.
Old 03-12-2013, 07:55 PM
No.
Old 03-12-2013, 08:10 PM
j2the-e's Avatar
No.
What do you mean no? I realize that pulling the lower control arm out may give enough clearance. But thats not what that adjustment is for. Its for camber and caster.
Maybe you can afford new tires every couple months, but I cant
Quick Reply: front shocks keep getting mangled by chasis bumpstop
