Front input Bearing help!
Hello, my issue i need help resolving is:
I am in the middle of a head gasket repair, and i have my engine down to the block. My dad whos helping me thinks that it would be easier to do my clutch job by pulling the engine with a picker, as all thats holding the engine in is the mounts and tranny bolts. BUT: we also need to replace the front input bearing in the tranny. Is the Front input bearing doable without dropping the tranny? If not, we are going to put the motor back together and then drop the tranny, do the clutch + input bearing. Thanks in advance, any insight is much appreciated
Uhh..yeah? If you can see the input shaft in the bellhousing, you can do the input seal. Get the clutch fork outta the way, its right there. Gonna be sitting on the IFS to do it, but yep, I did mine before I found yotatech! Oh. Bearing. See, I did seal. Why the bearing? Trans issues before? Noisy-like? It should be fine.
No shifting problems, just when in neutral or in gear with the clutch engaged a noise, hard to explain. Sounds like a bad bearing . Sooo will I have to drop the tranny to get to it? You didn't really answer my question
Heh. You're right. I think that may be a removal and split the case halves kinda thing. Any luck looking around here? I loaned out my book, so I can't thumb thru that right now...
Ive got a Haynes, but I dont believe it goes into that much detail about tranny internals. Thank you! Still open to discussion if anybody else wishes to comment.
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
coffey50
07-28-2015 10:55 AM
dinks07
07-15-2015 05:34 PM
