Front hub gasket name/part number
Old 02-18-2013, 07:01 AM
dr_worm's Avatar
I've been all over this forum looking for a name or number of the non-reusable gaskets/seals that I'll need to replace while doing my rotors. I'm not doing bearings or oil seals, I just need the seals that I'll have to replace after I get the hub off to replace the rotor.
The FSM doesn't specify a part number, and I can't seem to find what I need on RockAuto.
Any help?
Old 02-18-2013, 08:32 AM
brianh699's Avatar
Front Axle Outer Shaft Flange Gasket 4342260010 this is the one under the hub. Free Wheel Hub Gasket 4353160010 this is the star gasket that goes under the dial.
You should be able to get them at dealership they're pretty cheap and usually stocked.
Old 02-18-2013, 08:49 AM
dr_worm's Avatar
Thanks a million
I wish I could +1 you on here or something, thank you so much
Old 02-18-2013, 09:19 AM
brianh699's Avatar
That's what this forum is for. Your welcome.
Colington
03-08-2020 09:51 AM
09-04-2015 09:27 AM
87blyota
07-10-2015 04:31 AM
ItsJustD
07-07-2015 07:49 AM
Quick Reply: Front hub gasket name/part number
