Front in grinding need help
Old 12-29-2014, 05:22 AM
curry's Avatar
Can anybody help me I have a 1988 toyota pickup 2.4 efi 4wd it has a grinding noise in the front it will grind when I lock my hubs in and still in two high and when in 4 high or 4 low it will not grind when hubs unlocked
Old 12-29-2014, 07:21 AM
MudHippy's Avatar
Check your spindle bushings. They probably need greased, or replaced. You might want to inspect your front driveshaft u-joints too.
Old 12-29-2014, 05:31 PM
curry's Avatar
The noise is comeing from driver side and it isn't always grinding only every now and then
Old 12-30-2014, 05:11 AM
MudHippy's Avatar
Sounds familiar. Like I said. Spindle bushings...
Old 12-30-2014, 06:30 AM
mountainbrew's Avatar
I may have a similar issue right now. 86 4Runner 22re 5spd. I was searching everywhere, but the problem(as stupid as it sounds), I can't figure out how to describe the noise!! This happens to me as well when the hubs are locked, regardless of whether or not it's in 4wd. The noise sounds like a cross between the t-Rex from JP, and gym shoes squeaking on linoleum. For sure not the classic clicking CV axle: However that sound only happens occasionally, and there is a whirring sound that happens all the time (hubs locked) and almost sounds like road noise from the tires. My searching has led me to believe it's the spindles, especially since it started happening to me during the first snow/ cold snap. Let us know what you find!
jashoeuh
11-26-2017 07:01 AM
Shaun Crystal Gomban
07-30-2015 10:13 PM
PlayAwhile
07-20-2015 11:36 AM
kvanzandt1
07-18-2015 10:15 AM
mengquis
07-13-2015 10:39 AM
Quick Reply: Front in grinding need help
