Front frame repair?
Front frame repair?
any tips for replacing the very front frame just the area around the front body mounts? that hole area is going to rust away in 2 years and already has holes?
the control arm area is mint!
with out seeing a picture of it maybe this might help:
http://www.offroadsolutions.com/prod...ccessories.htm
3rd item down HD front frame brace from ORS
I think it would be easier to swap the whole frame you are already going to have to remove everything, but it also depends on where and how bad the rust actually is, you may be able to torch it out and patch it.
09-04-2015 09:27 AM
