Front end noise...help, thanks - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-04-2006, 03:42 PM   #1 (permalink)
Swissdrums's Avatar
Send a message via AIM to Swissdrums
Hey everyone,
So i know it is difficult explaining noises online, but i am going to do the best i can...
For the past 2 days, my front driver side seems to be making a consistant high pitched buzz/squeal. I know it is not my spindle bushings becuase my hubs are not engaged in the "locked" position. When the noise first started, it would only come about when doing right turns. Now, it is at the point as to where it stays with me untill I do a hard left.
My spindle bushings were on the verge of going, but i havent needed to lock the 4wd in for a while, so i figured this was not a bothersome issue.
It does not seem to be any engine components becuase i was reving the engine and there was nothing. Nor was it my power steering becuase when i turn sitting still, nothing either. It only happens when i am moving.
Again, it is a high pitched consistant squeal/buzz coming from the driver side front. Thanks for all your help. Any information on what to look for would be great. Thanks!
-Mike
__________________
1994 Toyota 4Runner V6 Auto 4WD
Swissdrums is offline
Old 04-04-2006, 06:36 PM   #2 (permalink)
Swissdrums's Avatar
After a 5 page essay on an AP Language and Composition Prompt and still nothing?!?!!
__________________
Old 04-04-2006, 07:52 PM   #3 (permalink)
AH64ID's Avatar
Send a message via MSN to AH64ID
Well the bearing are turning no matter what position your hubs are in. The only thing that doesn't spin is the CV, which doesnt carry any load.
I would quess that you need to pack your wheel bearings. Probally only started in a turn since the force changed a little. Now they are getting dry. I beleive Toyota reccommends packing them every 12K, mabye its 24k?? I try to do it every 12-18 months.
__________________
-John
'05 Dodge 3500 SRW 4x4 SLT 5.9 Cummins QC LB NV5600
2003 SR5 4Runner, V6 4WD. 1" cornfed lift
Previous Toyota's '92 Red Truck NALA
Speed doesn't kill, its the sudden stop that hurts.
AH64ID is offline
Old 04-04-2006, 08:19 PM   #4 (permalink)
Swissdrums's Avatar
What do you mean "packing" them? Sorry if thats a dumb question, i assume it means grease/lube?
Thanks for the advice though
__________________
Old 04-04-2006, 10:37 PM   #5 (permalink)
AH64ID's Avatar
Yes, you pull them out, and the simple way is to put a ball of grease in your hand and beat the bearing into your hand, like packing a can of chew. Do this until grease is in and around the entire bearing, and then some. This is also a good time to get a hub rebuild kit and go thru everything. Not sure about factory hubs but Warn makes a kit just for that.
__________________
-John
AH64ID is offline
Old 04-05-2006, 07:15 AM   #6 (permalink)
Injohneer's Avatar
Quote:
Packing bearings is like feeding babies. Keep pushing it in until it comes out the other end.
__________________
Trail/Build Rig: 1981 Toyota Pickup 4x4, flatbed
Tow Rig: 2001 Chevy 2500HD Duramax 4x4, X-cab Long Bed. Will be my tow rig, when I get a trailer.
RIP: 1995 4Runner.
Injohneer is offline
Old 04-05-2006, 11:22 AM   #7 (permalink)
AH64ID's Avatar
Quote:
Originally Posted by Injohneer
Looks like your feeding your truck creamed carrots
__________________
-John
AH64ID is offline
Old 04-05-2006, 11:39 AM   #8 (permalink)
Injohneer's Avatar
oh no, I got the grease and baby food mixed up again...
__________________
RIP: 1995 4Runner.
Old 04-05-2006, 12:31 PM   #9 (permalink)
AH64ID's Avatar
Well, I hope your wife is the one changing the diapers
__________________
-John
AH64ID is offline
Old 04-05-2006, 01:20 PM   #10 (permalink)
Swissdrums's Avatar
thanks guys...one question, i have seen that bearing before, is it from the hub or front axel?
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
front end noise? Yota Runner 86-95 Trucks & 4Runners 5 06-10-2006 06:30 PM
Front end noise slustan 95.5-2004 Tacomas & 96-2002 4Runners 8 12-17-2004 08:00 PM
Front end noise jkirk 95.5-2004 Tacomas & 96-2002 4Runners 3 08-30-2004 04:43 PM
Front End Noise Cebby 95.5-2004 Tacomas & 96-2002 4Runners 5 02-09-2004 04:19 PM
Front end noise Cebby 95.5-2004 Tacomas & 96-2002 4Runners 2 12-30-2002 10:18 AM
2009 InternetBrands, Inc.
