front end noise HELP!!!!!!!!
Old 11-19-2008, 11:17 AM
djkron's Avatar
Hey everyone,
The problem i am having on my 1991 4runner 4x4 3.0 is this,
On the passengers side front end is a grinding noise that is equaled by the rotation of the tire, i thought it was the wheelbearing and replaced it, at the same time i inspected the tie rods and front axels. The axels seems solid but i have been told that maybe the problem. The noise is only there when the vehicle is cold and all but goes away after a good drive. Also when turning a corner the sound fades until i straighten the wheel then it grows in volume. There is no hard clunk that is typical of a blown front axel when i turn.
This is where it gets interesting, the above paragraph is when i am in two wheel drive, when i put it in 4x4 high the sound is gone completly, but when the passenger tire hits a bump it will pull almost violently to the right, this would indicate to me anyways that i have a bad tie rod but as i mentioned they seemed fine.
So Guys I need u to work your magic for me please because i am a poor SOB and can't afford a mechanic.
If anymore info is needed let me know, also i do not have manual hubs.
Old 11-19-2008, 11:40 AM
Dasuprawolf's Avatar
Its the spindle bushings. Had the EXACT same thing with my truck.
Theres two bronze bushings at each end of the spindle for the axle, there wore out and is a lot of up and down movement or slop.
Hope you can picture what im talking about.
Old 11-19-2008, 12:11 PM
djkron's Avatar
Thanks Man!!!
Hey just wanted to say thanks for the info, the bushings would have been my last guess, if that fixes the problem i will let you know.
And For anyone else who has the same problem i stumbled across this little gem
https://www.yotatech.com/~corey/tech...imrockford.htm
Old 11-19-2008, 12:14 PM
leebee's Avatar
you found it! now, get to it!
lee
Old 11-21-2008, 10:52 AM
yep, you got it! and the 4x4 is much easier, no need to use any kind of press.
09-04-2015 09:27 AM
Daneums
08-20-2015 05:36 AM
razorman8669
07-12-2015 12:13 PM
mlavery85
07-12-2015 10:33 AM
Jonny246
07-12-2015 04:51 AM
Quick Reply: front end noise HELP!!!!!!!!
