front end grinding noise
1 Post
ppl always turn there head..and look to see what is making all that racket and its my truck..but im gnna replace the bearings tomarrow
rumble strip noise
Hey did y'all ever figure out what was causing this horrible sound mine is doing the same thang its a 90 Toyota pickup 4x4 22re with manual locking hubs I replaced wheel bearings an its doing the same thang
Sorry for the late reply. My problem was inside the spindle, there is a brass bushings where the CV axle goes trough. If it is not greased up, it will start spinning in its socket when engaging 4x4.
My noise got fixed up when I pulled the CV out an greased up the shaft and the face that lays against the spindle.
Hope this helps!
Hope this helps!
I know this threads old but need help
This exact same noise just happened to me, I'm about 65 miles away from home, all freeway, am I safe to drive home or am I going to have to pay for a tow? It's slowly getting louder, and sporadically goes away after hitting a bump or something.
#25
I imagine you made it home by now...but that noise was due to the CV axle spinning the hub bushing. So no 4x4 and no locked hubs should equal to no noise....Assuming it was the same problem i had. Based on your description of hitting bumps and the sound gone, it sounds spot on the issue.
I would not mess too much with 4x4 untill you fix the issue.
09-04-2015 09:27 AM
mengquis
07-13-2015 10:39 AM
