Front drive shaft questions
Old 01-29-2013, 11:10 PM
4runnerJC's Avatar
Front drive shaft
How much do you guys end up paying for a custom front drive shaft? I got a place telling me around $375. Is this high, low, okay?
Old 01-29-2013, 11:15 PM
4runnerJC's Avatar
This is what it's going on. Dana 44 with 4.09 gears front, 4.10 Toyota rear.
Old 01-30-2013, 04:06 AM
Dave the welder's Avatar
I just did a square driveshaft that will be used for low speed (under 20 mph) for around $20. I do plan on getting a "correct" shaft but this got me going and it will be a trail spare. $375 isn't a bad price.
Old 01-30-2013, 05:56 AM
Dreidel's Avatar
get a d44 shaft and a toy shaft and then combine them. im making a custom long travel shaft which is going to consist of 2 slip joints welded together and then shorten the tube.
Old 01-30-2013, 07:25 AM
waskillywabbit's Avatar
That's ok.
:wabbit2:
Old 01-30-2013, 09:47 AM
4runnerJC's Avatar
Thanks for the replies, I'll just have it made, just trying to see if it was a fair price.
Old 01-30-2013, 10:38 AM
fillsrunner4's Avatar
Sounds about right for a new one made for ya
Old 04-12-2013, 09:13 PM
4runnerJC's Avatar
New front drive shaft
http://s1281.photobucket.com/albums/...c3c4d6ca-1.jpg
Old 04-12-2013, 09:16 PM
4runnerJC's Avatar
My son paid $479 for it custom made. It's for a Dana 44 front axle to Toyota gear box. I thought it was kinda pricey but if you want to play you gotta pay right?
Old 04-24-2013, 01:45 PM
4runnerJC's Avatar
http://i1281.photobucket.com/albums/...psa3567b74.jpg
My son got his front drive shaft made and this is how it sits at normal ride height. Is the shaft supposed to be showing so much spline? The builder claimed you could catch air and the shaft will not come apart. I just wanted to know how others shafts sit.
Old 04-24-2013, 01:48 PM
4runnerJC's Avatar
http://s1281.photobucket.com/albums/...ps25c2c2e1.jpg
Here's another pic. It rides fine and hasn't been off road yet.
Old 04-24-2013, 02:11 PM
Co_94_PU's Avatar
Use the "IMG" code so it in-lines the picture, wouldn't hurt to force the flash on either. You might get better responses, we're helpful but still kinda lazy and don't wan to have to work to help
It's probably fine if the guy says he did it right it's probably right, if it's not you know who to take it back to. If you want to know exactly how much is left you need to jack up the frame so the axle hangs and mark it then remove it and measure what is left inside.
Old 04-24-2013, 02:52 PM
85TurboRunner's Avatar
who did the measuring?
Old 04-24-2013, 09:26 PM
4runnerJC's Avatar
Coast driveline in Ventura
Old 04-24-2013, 09:50 PM
4runnerJC's Avatar
Old 04-25-2013, 12:04 AM
wyoming9's Avatar
Red face
Just curious was the vehicle there or did they just have the old drive shaft??
Did anyone mention just how much lift the vehicle had??
If this was a new driveshaft I would myself have wanted the tube longer.
Perhaps it was the case of here this one will work!!! That customer never picked it up!! I can sell it twice.
Old 04-25-2013, 09:11 AM
Dreidel's Avatar
i always heard that at ride height there should 1 to 2 inches of splines exposed but thats with no lift i couldnt imagine it being any diferent for a lifted truck
Old 04-25-2013, 10:12 AM
4runnerJC's Avatar
The truck was left at the driveline shop. The truck has the 8 in trailgear lift. I was just surprised to see so much spline exposed at ride height. Like mentioned, if it comes apart ill take it back thanks guys for the input.
Old 05-11-2013, 12:41 AM
Fossilized
Staff
dropzone's Avatar
never heard of a trail-gear lift over 5"
FYI-merged your similar d/s threads together
God's Bounty Hunter
07-08-2015 12:54 PM
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
TNRunner88
07-01-2015 08:00 PM
Quick Reply: Front drive shaft questions
