Front differential help
Old 08-04-2011, 01:05 PM
HAWAIIANSTYLE's Avatar
hi all,.. i got a 94 4runner 4wd.. my problem is a leak on the passenger side where the half shaft connects to the front differential. i took off the cv axle and inspected the area of the differential and found a great amount of grease building up, also there is a lot of play compared to the driver side. is this an easy DIY fix? im assuming that the seal on that side needs to be replaced. being that there is a significant amount of play when i grab the center of the cv axle and give it a shake,.. im wondering if theres a bearing on the inside of the differential that has gone bad. do i have to remove the diff. to replace the seal? i'd appreciate any help. thanks
Old 08-04-2011, 01:34 PM
ZUK
ZUK's Avatar
I almost forgot I had this link on my site...
http://gearinstalls.com/needlebearing.htm
Old 08-04-2011, 04:32 PM
thanks ZUK,.. that link was very helpful on what i was looking for. im still curious if i need to drop the diff. to change out that bearing, im pretty sure it needs to be changed.
Old 08-04-2011, 05:32 PM
rattlewagon's Avatar
Diff must come out. I have the same issue, started a thread about it last week.
https://www.yotatech.com/forums/f116...issues-238690/
Ladythump
22
11-09-2015 08:53 AM
justdifferentials
Just Differentials
08-15-2015 05:25 PM
ripp96
07-25-2015 02:32 PM
scottyg486
07-19-2015 05:34 PM
AaronM
07-08-2015 07:15 PM
Quick Reply: Front differential help
