front crank breather blowing oil
Old 02-29-2008, 10:22 PM
runnerfreak88's Avatar
ok so replaced the pcv valve hose in the back with an air filter and the one in the front by the oil cap too, but now the front blows oil from it not alot but enough to get a thin coat oil all over my engine. I have seen people do this before but is it suppose to loose oil? im perty sure not. by the way it doesn't have a pcv valve on the front one and i don't think it is suppose to but im not 100% sure. does any one know how to fix this?
Old 02-29-2008, 11:03 PM
87toy.'s Avatar
called blow by, getting to much air will do this, what kind of filters are u useing? do u have a pvc valve on the rear?
Old 03-01-2008, 10:07 PM
ya have a pcv on the rear the filters are just some cheap k&n knock offs from auto zone. not quite sure why it does have so much pressure becuase it runs like its new its a very strong engine thats why im not worried about it being blow by because it wouldnt be running very well
Old 03-02-2008, 07:18 PM
87toy.'s Avatar
umm.... i had a vw motor rebuilt a few years ago and after a few hundred miles i had this happen, turned out to be bad rings and it ran great, for awile. but thats a old vw motor.
Old 03-02-2008, 08:04 PM
well i guess time will tell not to worried though never uses oil so im sure iv got good rings
Old 03-03-2008, 09:19 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
I hardly had to add any oil nor did my 22re ever smoke, but the rings were so encrusted with carbon I had some pretty decent blow by......after about 210k miles was when it started.
Old 03-03-2008, 05:45 PM
ill have to try some sea foam see if that does anything cool thanks
Old 03-03-2008, 09:11 PM
thook's Avatar
Try if you like, but I'm afraid it won't. Seriously....I've tried a number of things. Auto-RX and Seafoam included. Carbon is resilient stuff.
Old 03-03-2008, 09:14 PM
toytech76's Avatar
BG makes a engine flush kit. It contains a quart of flush that you dump in the eng and let the eng idle for an hour. Then you change the oil again and put in an additive. It actually works pretty good
Old 03-03-2008, 09:20 PM
apalmer1's Avatar
you can have an engine run smooth and evenly and still have excessive blowby. The thing that makes an engine run like crap is uneven compression, if all cylinder have low compression it will still run fine just have less power. Do a compression test, dry and wet. if your compression doesnt increase considerably with oil in the cylinders on the wet test then you have found your problem.
Old 03-03-2008, 09:35 PM
thook's Avatar
Yeah, but the compression test won't say anything for bad oil rings. They have nothing to do with compression. That's my understanding of it, anyway.
Old 03-03-2008, 09:40 PM
apalmer1's Avatar
compression tests have everything to do with rings. When you do a wet compression test you squirt oil into the cylinder. The oil takes up volume in the combustion chamber, and so the compression should be higher than it was doing a dry compression test. If the rings are warn the oil will seep past the rings into the crankcase and you wont see much of an increase. This doesnt just pertain to the oil controll ring specificaly since the compression rings are designed to contain the air fuel mixture in the cylinder, which is obviously much less dense than oil.
Old 03-03-2008, 09:46 PM
toytech76's Avatar
You kind of have it backwards. If the top 2 rings, which are the compression rings, are worn, you will have a large increase in compression if you squirt oil in the cyls. There will be very little if any increase if your valves are bad. Oil in the cyl's will not tell you if the oil control rings(bottom rings) are bad or not
Old 03-04-2008, 03:21 AM
see thing is its still very powerfull have 94 runner with bad rings that takes for ever but i can go up free way hills going 70 still in 5th gear. have beat a couple 2.7's lol. its just a very strange thing
Old 03-04-2008, 10:35 PM
thook's Avatar
You can have good compression and still have leaky oil rings. Not so strange.
bigjstang
08-25-2021 12:41 AM
redneck17
07-17-2015 07:44 PM
87blyota
07-10-2015 04:31 AM
Huntingtruckcletus
07-08-2015 05:26 PM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: front crank breather blowing oil
