Found Wire
Old 12-20-2009, 10:02 AM
PickupMan's Avatar
Found Wire
I found the wire that was making my truck start on fire. Can anyone tell me what the connectors are for that I circled in the picture. The wires are frayed on them and I have a Haynes and Chilton manuals, but they don't label these to plugs. I have also tried AllData at my school, I just got the diagrams that are in my manuals. Thanks for the help.
Old 12-20-2009, 11:07 AM
fierohink's Avatar
Just to get my bearings, that's the block on the pass side fender rail just back from the battery correct?
Old 12-20-2009, 12:23 PM
milehigheric's Avatar
This is the interior fuse panel. One connector is the power input (both switched and constant) from the ignition barrel. The other is the output to the circuits in which the fuses are labeled.
So bassicly you have narrowed your issue down to every circuit in your truck At least you know where the frayed wires are. Fix them and you shouldnt have an issue unless there is an underlying cause.
Old 12-20-2009, 01:27 PM
PickupMan's Avatar
Alright, thanks for the help.
Old 12-21-2009, 12:15 PM
fierohink's Avatar
See now that makes more sense. I was think the box on top was the diagnostics terminal that hangs off the junction box under the hood, but there seemed to be too many relays.
MO transplant
04-23-2023 11:58 AM
icentropy
09-16-2020 02:47 PM
raptor510
02-17-2017 07:11 AM
msane99
07-17-2015 10:13 AM
Johntom240
7
07-13-2015 12:18 AM
Quick Reply: Found Wire
