YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 12-31-2007, 08:15 AM   #1 (permalink)
Found the oil leak--oil pan removal?
The major oil leak on my 94 3.0 4-runner suddenly got so much worse it was easy to see it coming out between the oil pan and the block all around, not just in back. Looking carefully I can see that someone used a cork gasket and that is why the bolts were loose. I need to re-do it with the proper sealant.
But can the pan be taken off without pulling the engine? It looks like I could get it off by removing the steering tie rod, anyone know?
Thanks!
morrison is offline
Sponsored Links
To remove this ad, register today!
Old 12-31-2007, 10:51 AM   #2 (permalink)
leiniesred's Avatar
I helped a guy who used to (maybe still does) post on here who tried this.
He had a TON of the front end apart when I came over with the tie-rod puller!
We were able to get the pan out eventually, but it wasn't the easiest way.
You really want to pull the front differential out of the way. It is only 24 bolts. including the skid.
__________________
yeah.
leiniesred is offline
Old 12-31-2007, 11:09 AM   #3 (permalink)
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
Or you can pull the 4 engine mount bolts and raise it up enough to get the oil pan out.
I would suggest pulling the diff or at least getting it out of the way via lowering it. That will make the intall SOOOOO easy.
__________________
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by Junkers88 View Post
Good lord this thread is like herpes. Everytime I think it's gone there's another outbreak.
Quote:
Originally Posted by 1972TLC View Post
DC, you're always #1, don't worry ;)
DeathCougar is offline
Old 12-31-2007, 11:54 AM   #4 (permalink)
toytech76's Avatar
Yes...I say drop the front diff so you can drop the pan past the pickup. Go to toyota and get a tube of black FIPG. The stuff is the best sealant. There is also a windage tray between the block and pan you should reseal since you are there
toytech76 is offline
Old 12-31-2007, 02:21 PM   #5 (permalink)
OK, thanks guys. I'll tear into it in 2008.
Happy New Year!
JIM
morrison is offline
Old 12-31-2007, 04:07 PM   #6 (permalink)
neoworm0's Avatar
HaHaHaHaHa.
Damn that makes my SAS worth it right there. LOL! Good Luck with that. I don't envy you.
__________________
1995 Toyota PU SR5 V6, A few mods.
neoworm0 is offline
Old 12-31-2007, 04:16 PM   #7 (permalink)
Targetnut's Avatar
you can unbolt the front diff housing from the frame and leave it attached to the axles and just let it hang down, this will give you the room you need.
__________________
Targetnut
don't talk about it, just do it!
Precision Import Service
'93 2WD 22RE, Ported w/os valves, custom intake manifold, crane cam, 295cc injctrs, Supra AFM, Supra fuel pump, adj fuel pres reg, 70mm throttle, LCE header, V6 Taco cat, 14lb flywheel, Kevlar clutch, W58 and short shifter, 4.10 gears w/Truetrac, drop spindles and blocks, 245/50-16 Yokos on 16x8 wheels, 4WD fenders, bumper, and valence, skinned tailgate
Targetnut is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Oil pan removal-Which way is best??? jimtanner 95.5-2004 Tacomas & 96-2002 4Runners 3 09-17-2006 07:32 AM
3.0 oil pan leak twstedrage 95.5-2004 Tacomas & 96-2002 4Runners 3 10-16-2005 10:40 PM
Oil Pan Leak Question Bassinfool Maintenance & Repair Archives 5 10-16-2005 10:38 AM
22R Oil Pan leak 4Rocker Maintenance & Repair Archives 3 07-02-2005 01:11 PM
Oil Pan Removal ??? NathanBERG 95.5-2004 Tacomas & 96-2002 4Runners 2 01-04-2005 03:03 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
