Flywheel cover
1 Post
Flywheel cover
Well,upon an underside inspection today. I noticed I have no flywheel cover.
Yes...I know that the teeth could potentially be damaged by road debris and other nasty things.
Anyone have a flywheel cover they'd like to unload or know where I could get one?
I checked the standard auto supplier web sites and found nothing.
A btter question...am I supposed to have a flywheel cover or is this a nasty trick from the manufacturer,by not installing a flywheel cover?
for the 3.0L with a 5spd there should be a small dust sheild that bolts to the bottom of the belhousing.which seems to be the part you are describing. yes you should have one, get it either at a boneyard or from the dealer.
Location: Yotatech, because Pirate is too expensive. NorCal.
I dont beleive you can take it on/off without removing the tranny/flywheel. Its bolted to the block I think. You can see it is between the trans support brakets and goes up between the belhousing and block.
1 Post
Ooooooooooh...my bad friends....I have 3.slow thats an automatic.(which is listed in my sig.)
All I know is that I can clearly see the flywheel...which can't be good.
P.S. Their is no such thing as Toyota's in boneyards around me,and I'm scared of what the dealership would charge for a new cover.
Still looking for a used one if anyone has one for sale.
he's gone
7
12-03-2019 07:08 AM
09-04-2015 09:27 AM
TransAmBandit
07-28-2015 11:30 PM
