Fluids
Fluids
I have a 95 4runner 3.0. Does anyone suggest certain transmission rear and front diff fluids. Also transfer case. And how much. I appreciate all the help I receive on here.
Mobil1 is what i use, i think the ft and rear take a little over 2qt each. if you have a auto use dex 3 in the trans and transfer. i think the trans takes 4ish qt when you just drop the pan and the transfer case takes 4 or 5. do a search and you will find the exact numbers
Do yourself a favor and use the search function as you will find a ton of threads addressing that same issue. There are also links in threads to online factory manuals here also. Check out this thread here where I posted about which gear lube to use in the tranny etc...
