Sign in using an external account
| 86-95 Trucks & 4Runners 2nd/3rd gen pickups, and 1st/2nd gen 4Runners with IFS |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
Fluctuating Idle problem 90 V6
__________________
~Alex My cars.. 93 Acura Legend cpe 6spd ; 93 Legend cpe auto (parts) ; 90 T4r V6 5spd ; 82 Yamaha Maxim 550 Past cars... 02 Dodge Durango ; 89 Lude 4ws 5spd totaled :( - not by me! ; 96 Chevy Blazer 2dr Other cars in the fam 05 Dodge Grand Caravan (dads) ; 01 Dodge Ram B3500 (dad's) ; 01 Civic (moms) ; 00 Lexus RX300 (sisters) ; 96 Cherokee (sisters bfriend) |
#2 (permalink) |
Personal
Sales Rating: (0)
First thing to look for is vacuum leaks. But since you haven't changed anything this is unlikely. Under the category of 'things that go bad' the TPS seems to be at the top of the list.
#3 (permalink) | |
Personal
Sales Rating: (0)
[OP]
Quote:
also i want to add that after further driving it around it, it does looks like the brakes effect it doing it. also i think i'm going to do a smoke test too on monday (force smoke thru the vacuum system to see for leaks) anything else you guys can think of let me know. thanx!
__________________
#4 (permalink) |
Personal
Sales Rating: (0)
wheres does it idle at
__________________
07 Tundra d-cab limited 5.7L 4x4 was my moms r.i.p 3/19/11 98 4runner SR5 3.4L 5spd 4x4 E-Locker sold 10-2-11 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 97 honda civic lx 4dr ls vtec |
#5 (permalink) |
Personal
Sales Rating: (0)
[OP]
when it fluctuates it goes from 850ish to 1400ish, then smooths out to about 1250ish. but i think normally its at about 1100ish, when it does do the fluctuating thing. Eitherway i think its idling a little to high, i think before it used to be lower.
__________________
#6 (permalink) |
Personal
Sales Rating: (0)
the idle is to high try adjsuting it if that dont solve the problem must be a vacuum leak
__________________
#7 (permalink) |
Personal
Sales Rating: (0)
[OP]
yea, i found the screw earlier when i checked the oil yet again. I'm going to add that to the list of things to check on monday. I don't have anything to give me a digital rpm read out here at home. I want to set it back to spec, i also want to check and adjust the valve clearences. I don't think thats been done in a long time.
How often do you guys find that the valves need adjusting??
__________________
#8 (permalink) |
Personal
Sales Rating: (0)
Check the air intake hose that goes into the actual intake manifold. It's about 3inches in diameter, the pcv hose is attached to it. They are made of a harder rubber and like to tear at the bends, this will casue your rpms to vary under aceleration or decelration, and at idle as it lets intake air exscape. Mine was having idle problem and surging problem, when I indstalled an K&N FIPK kit it was torn in two spots. If this is torn I have an extra one that is used in good shape for sale.
__________________
Only in a YOTA, cause the force is with you. 92 4runner, 3.0, 5sp K&N FIPK |
#9 (permalink) |
Personal
Sales Rating: (0)
i just adjust the idle level by ear and looking at the tach
__________________
07 Tundra d-cab limited 5.7L 4x4 was my moms r.i.p 3/19/11 98 4runner SR5 3.4L 5spd 4x4 E-Locker sold 10-2-11 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 97 honda civic lx 4dr ls vtec Last edited by Elton; 12-11-2006 at 12:00 PM. |
#10 (permalink) |
Personal
Sales Rating: (0)
[OP]
idk, its weird but the idle problem just went away...weird huh. I still think the idle is set too high. I didn't end up looking at her at work but i'll try and adjust the idle by ear, i just wanted it precise
thanx for the help guys...
__________________
| Tags |
| 3vze, 90, 91, 93, acura, blazer, fluctuate, flucuating, idle, idling, legend, problem, problems, toyota, v6 |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 3.0 fluctuating idle | hellas | 95.5-2004 Tacomas & 96-2002 4Runners | 16 | 01-16-2012 06:19 PM |
| Fluctuating Idle?? | 4rnr | 86-95 Trucks & 4Runners | 29 | 10-06-2010 12:42 PM |
| 90 V6 Idle Oscilation? | Tucson T4R | 86-95 Trucks & 4Runners | 1 | 12-25-2006 04:45 PM |
| 90 v6 running rich, rough idle, stalling...HELP! | wheelin4cheap | 86-95 Trucks & 4Runners | 9 | 04-12-2006 10:15 AM |
| Idle keeps fluctuating | Stoney Point | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 09-26-2003 10:05 AM |
