Flickering oil light
Well, i hit a bump today, and my oil light flickered on then back off.
It's been doing it since i hit that bump.
Any ideas?
Carbed 22R in an 87' pickup, so no fancy computers or anything
Any ideas?
Found it, the wire is uhhh...
It's about to fall apart.
I disconnected it, i'll probably fix it this weekend.
I also came upon another wire, it's red with a broken connect and an inline fuse.
It runs all the way back to the gas tank
The blue connector looks like it's snapped. And i didn't put this in, because my lightbar wire is a much lower gauge..
Has oldschol inline fuse setup..
There was no fuse in it, i checked.
And it runs along the frame to the back.
hmmm...
i guess i'll hunt it down then.
Update: It disappears by my gastank.
When i put a fuse on it and put it on the hot side of the battery, nothing happens.
No amp in cab. Nothing to suspect an amp.
The first time the carpet was even pulled up was when i did it.
It's a pickup, not a runner
And there would be no explosion in the tank. Not enough oxygen to start a fire.
Could be anything...I would suspect something like power to an esky or some form of rear accessible power. You will probably find it goes no where, explaining the previous owner has taken the fuse out.
09-04-2015 09:27 AM
Odin
07-15-2015 09:28 PM
