flatbed tailer lighting
Old 02-22-2012, 01:43 PM
yotarover's Avatar
Finally got my flatbed a real one . anyways im having issues with the lights. i've got 2 blazer sub tail/turn lights they have 2 wires. i have tail lights. brake lights until i turn on the signals . i've spent about hr looking for a diagram that list the colors and their purpose. nada im thick skinned so bring on the flaming.
anyone happen have the colors and their purpose or a link. need to get this done soon. * im replacing the stock tail lights with the trailer lights* from the hardness i've followed the colors still having issues though
Old 02-22-2012, 02:17 PM
wyoming9's Avatar
Red face
trouble is our lights use a different blub for the turn signals
The GM style use one wire for the brake/turn signals and another for the tail light.
You might be able to get on of those trailer converter boxes to run off of 4 wires.
Trying to run 2 wire lights off a 3 wire harness would drive anyone crazy.
1987 the tail light wire is green brake lights are green/white
leftturn is green/blue right turn is green/ yellow
back up lights are red/blue
Grounds are White/black
I don`t know if that will help
Old 02-22-2012, 02:20 PM
xxxtreme22r's Avatar
Your going to need a trailer light converter if you plan on running only 2 red lights in the back. Toyotas are a 4 light system. Separate brake light then the turn light. No way around it.
Old 02-22-2012, 04:41 PM
yotarover's Avatar
i have brake,tail on the drivers side. works fine *turn has a diff lightdont care about the hyper flash..
passenger side is where im having problems.
red-black stipes
G-red stripes
White black
G-black
white black stripes
when i hooked them up the same it didn't work, pig tailed the brake light it worked, but no tail lights.
Old 02-22-2012, 06:51 PM
yotarover's Avatar
fixed it, no box needed. stop/tail in red, and orange turn signals with their own. the passenger side stock tail light was wired a lil different. so i plug it back in connected the wires and after tracing and viola.
ashersullivan88yota
01-18-2022 05:37 PM
AkitaDog
09-01-2015 08:05 AM
PopsDad1
07-30-2015 02:21 PM
Odin
07-15-2015 09:28 PM
Quick Reply: flatbed tailer lighting
