Flashing Overdrive Light??
Old 09-14-2007, 10:02 AM
nick325i's Avatar
Question Flashing Overdrive Light??
I was driving my 88 Auto 4runner the other day and I noticed the overdrive light on the dash right above the radio was flashing. I'm sure it's trying to tell me something but I don't know what it means? I don't want to ignore it and tear something up. Thanks for y'all's help!
Old 09-14-2007, 10:07 AM
OSU4Runner's Avatar
Is your tranny shifting like it should?
Old 09-14-2007, 12:19 PM
nick325i's Avatar
It seems to be shifting fine, but I am waiting on some new tires before I really take it out and drive it.
Old 09-14-2007, 12:26 PM
4runnerx3's Avatar
the codes are for electrical problems with speed sensors and solenoids. It can't tell you if there is a mechanical problem with a solenoid. If it is shifting fine, it's probably a speed sensor. To pull a code you have to ground the square plug below, I'm not sure about '88 but this is for my '86.
here are the codes, the should be the same for '88.
Old 09-14-2007, 12:28 PM
4runnerx3's Avatar
When pulling codes, ground that plug, switch ignition on with the OD turned on and it will blink the code.
Old 09-14-2007, 01:02 PM
nick325i's Avatar
Thank you very much. I will do that this weekend!
chuckross1957
06-28-2019 10:19 PM
crammit442
7
11-29-2017 12:30 PM
Shoua
13
05-22-2016 05:19 AM
AkitaDog
09-01-2015 08:05 AM
keithporter83
07-24-2015 07:37 AM
Quick Reply: Flashing Overdrive Light??
