First valve adjustment, a little nervous
Old 03-22-2008, 04:37 PM
Junkers88's Avatar
Ok I've got the paper work, the tools, the time and I've read everything I can find on doing a valve adjustment on a 22re. I'm a little nervous though, anything I should look out for?
And in a new development the motor has started to push coolant into the overflow when it warms up. Head gasket???
*laugh* If this keeps up I'll end up rebuilding the whole dang thing in frame.
Old 03-22-2008, 04:41 PM
toyotatom93's Avatar
About the coolant, I'm no expert but I think it's normal to eject coolant into the res when it's warmed up...thats why you fill it up 1/4 of the way when it's cold, to leave room for when it's warm.
good luck on your adjustment btw
Old 03-22-2008, 05:16 PM
Matt16's Avatar
I adjusted mine hot to .008" and .012". Remember to put the feeler gauge between the rocker arm and the valve stem, instead of the camshaft. It did work though.
Old 03-22-2008, 09:17 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Junker....
Don't worry. You'll see..... it's real easy. Probably one of the easiest and greatest tune ups you can do for your truck.
Old 03-23-2008, 02:06 AM
Matt16's Avatar
Originally Posted by thook
Junker....
It's really the same measurement, just more difficult to get at.
Old 03-23-2008, 04:34 AM
DCYota's Avatar
Coolant spilling into the overflow is normal. Remember, when the coolant gets hot, it expands. The port for the overflow tube is at the top of the radiator filler neck...so when the coolant heats up, it rises in the radiator, and flows into the tube that leads to the overflow bottle.
When the engine cools, the coolant contracts and the level in the radiator lowers causing suction on that tube which then pulls that coolant from the overflow back into the radiator to keep it full.
Old 03-23-2008, 07:03 AM
MMA_Alex's Avatar
do a search if you want more tips.
Do it warm!
A little trick with the feeler gauge:
Put it in at the right setting and wiggle it in and out a bit, while tightening the adjuster until you lock the gauge in place. then just back the adjuster off just enough to slide the gauge out. that gets the settings right.
I like to spin the engine over a couple times when im done (by hand), and recheck em all.
Once you've done it a couple times you'll be able to do it really fast. The hardest part it dealing with all the vacuum lines to get the valve cover off.
Good Luck!
Old 03-23-2008, 03:32 PM
Junkers88's Avatar
Thanks for the help guys! I checked and adjusted the valves twice today in about 2 hours. That was really really easy!
Old 03-23-2008, 06:54 PM
DCYota's Avatar
Congrats! I need to get off my lazy butt this week and do the same. I'm overdue.
Blamalam
03-12-2022 07:34 AM
bigjstang
08-25-2021 12:41 AM
Jason Webber
09-02-2015 03:30 AM
DukeOfHazard
08-16-2015 01:48 PM
razorman8669
07-12-2015 12:13 PM
Quick Reply: First valve adjustment, a little nervous
