First Tune up
First Tune up
I just bought my first Truck and Toyota a few days ago its a 94 xtra-cab 4x4 3.0 liter and I plan on doing a tune-up right away . Whats the best Oil,plugs,and wires that I should use ? Should I just use stock recommendations . And what Oil,plugs,wires should I stay away from ?
Go with valvoline oil and enroll in the free engine warranty if your truck is under 125k miles, ngk plugs set the gap to factory spec (.032?), bousch or AutoZone plug wires cause of the lifetime warranty. Get the correct oil weight for your climate. Otherwise try to stay with thw stock specs
I personally don't like gtx oil
Here you go:
http://personal.utulsa.edu/~nathan-b...intenance.html
You're welcome. Don't forget to lube the chassis and drive shaft with a grease gun.
The OEM Toyota plug wires are affordable (ToyotaPartsZone) and high quality, and come with all the clips that hold them on the engine (already clipped onto the wires too!)
