first time run after a rebuild and break in - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-20-2007, 08:43 AM   #1 (permalink)
imtxn's Avatar
90 22RE, remanufactured top and bottom, Yeah the machinest used assembly lube when he built it, but I want to be sure the engine is lubed completely before I FIRE IT UP. I poured the new oil in from the head and installed a full oil filter. Be nice if I could fill the pick up tube and prime the oil pump too. Do you folks have any ideas about this? Thanks eh, Me
imtxn is offline
Old 01-20-2007, 09:51 AM   #2 (permalink)
SoCal4Running's Avatar
The oil pump is driven off the the crank shaft so you cant spin it up with a drill like some other engines. Some people prime the oil pumps with vasoline, but not worth the disassembly if it wasnt done. I would pull the plugs out and crank it over in short burst untill you have pressure on your guage then put plugs back in and go for it.
__________________
'86 4runner
22RE, 5-speed, LC Street EFI head w/ cam, LC Pistons, ARP Head Studs, Downey header, Dynomax 2 1/4" full exhaust, VDO water temp guage, 01-03 Tacoma cd\tape radio with 10" Bazzoka, Downey 2" rear springs, GDI radiator, Torus fan DONE!!!!
'68 Ford Mustang Fastback
Daily driver with a built 289 and a streetfighter trans.(Retired)
98 Subaru Outback-Took over daily driving duties
MicroMatic.com
Waco93.com
SoCal4Running is offline
Old 01-22-2007, 09:13 AM   #3 (permalink)
GSGALLANT's Avatar
Yep. Pull EFI fuse, remove spark plugs so it's easier on your starter and so your engine will spin faster, then turn and hold the key to "start" and let the engine turn over until you have oil pressure on your gauge (My 3.0L took approx 5 to 6 seconds) Then, re-install fuse and spark plugs, and fire it up.
__________________
2002 4Runner, Auto-A340F, 3.4L, 4.30 Gears
TJM T15 Front Bumper & Warn M8000, 4xInnovation sliders, Sonoran Steel 1.2 Lift, Toytec LCA Skids, Tundra Brake Upgrade (231mm), Extended rear diff breather, Deckplate Mod, Andymod, Dual batt setup with Optima blue top aux battery, Hardwired 1000W inverter, Aux fuse box, Full time power to 12V plugs, Yaesu FT7800R Radio, "4-air" system for airing up/down tires.
2004 Camry LE - stock (and will stay that way)
1993 4Runner has been sold
GSGALLANT is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
22re break in time notanymore 86-95 Trucks & 4Runners 4 03-15-2007 10:57 PM
New Motor Break In Time keithguts General Vehicle Related Topics (Non Year Related) 3 10-11-2006 01:29 PM
Break in run in WV Wazioc Trip-Trail Reports & Photos 17 03-29-2006 09:07 AM
30K Miles on SAW's, time to rebuild? Nitro Hotpants 95.5-2004 Tacomas & 96-2002 4Runners 13 12-15-2004 01:54 PM
ISR break-in time? Mikronized 95.5-2004 Tacomas & 96-2002 4Runners 3 10-23-2004 10:37 AM
2009 InternetBrands, Inc.
