| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Firewall Grommet
#2 (permalink) |
there should be one on the pass side pull back to the carpet and look
#3 (permalink) |
Locally we have a store called Ace Hardware. They have shelves and drawers full of misc connectors, nuts, bolts, gadgets.
Maybe you have a similiar store in your area and can sift through to find something close. I usually have good luck... even if the part I find is labeled for furniture or a computer or something. Imagination is your friend.
__________________
================ 1990 4Runner | V6 3.4 | 5spd | 240 someoddthousand miles | SR5 | SAS | RLS | 35's | ARB | TJM | 217 to 1 | W8000 - four wheels | three sticks | two hands | one trail - visit the sticki chronicles
#4 (permalink) | |
Quote:
I think he's looking for a hole in the firewall. There should be one somewhere on the passengers side. Otherwise you can just drill one, and get a little grommet plug to plug it with. Best bet is just to pull the carpet as stated above, and go searching. Last edited by MMA_Alex; 04-26-2007 at 12:07 PM. |
#5 (permalink) |
my '02 4R has a large one on the passenger side. I haven't checked my '93 4R, though.
__________________
2002 4Runner, Auto-A340F, 3.4L, 4.30 Gears TJM T15 Front Bumper & Warn M8000, 4xInnovation sliders, Sonoran Steel 1.2 Lift, Toytec LCA Skids, Tundra Brake Upgrade (231mm), Extended rear diff breather, Deckplate Mod, Andymod, Dual batt setup with Optima blue top aux battery, Hardwired 1000W inverter, Aux fuse box, Full time power to 12V plugs, Yaesu FT7800R Radio, "4-air" system for airing up/down tires. 2004 Camry LE - stock (and will stay that way) 1993 4Runner has been sold |
#6 (permalink) |
ummm - just drill one ?
Seals-it makes some nice grommets to use after ya make the hole |
#7 (permalink) |
The ECU wires go through the firewall on the passenger side.
Rob
__________________
1988 Xtra Cab Pickup ('94 22RE; 4x4; 5spd) Rancho lift w/ 33x12.5x15 tires & 5.29s |
#8 (permalink) | |
Quote:
I'd just make a new hole if nothing can easily be found. One trick I found that works well is taking a disposable pen and puncturing a existing seal. Once poked through, pull out the ink cartridge from the inside and you'll be left with a nice tube to pull wire. Once the wire is through, remove the tube and the grommet will generally seal pretty well around the wire if your rubber is in good shape.
__________________
#9 (permalink) |
I used one on the passenger side behind the charcoal canister in my '94. Pulled 8 gauge power wire for amps.
__________________
TNRabbit Stock '94 DLX XtraCab 4x4 5 spd, Newly Rebuilt 3VZE, 17" 2006 Alloy Wheels, 228k miles, AISIN Hub Swap 3.0 Rebuild Thread: http://www.yotatech.com/f116/crap-he...-ghost-108156/ |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| bodylift steering shaft/firewall grommet q? | RBA | 86-95 Trucks & 4Runners | 4 | 03-15-2007 07:00 AM |
| Help!!!!Please! PCV grommet ripped... | thook | 86-95 Trucks & 4Runners | 14 | 07-15-2006 11:39 AM |
| Antenna nut and grommet.... | LV_4Runner | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 06-24-2005 06:43 AM |
| brittle PCV grommet | geoduke | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 10-26-2004 09:15 AM |
| Replacing Factory Firewall Grommet | Beachrunner | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 03-03-2004 06:49 PM |
