Is it fine for steering stabilizer to wiggle on one end?
Old 02-04-2016, 05:55 PM
d-wood's Avatar
The steering stabilizer is fine on the frame side but the other side is real loose where it bolts. I can wiggle it a lot.
Old 02-05-2016, 12:16 AM
wyoming9's Avatar
Red face
Just where is the play??
In the stabilizer itself??
Between the stud and the hole.
You did tighten things??
Old 02-05-2016, 06:10 AM
d-wood's Avatar
The play is in the bolt that goes to the drivers side of the stabilizer not the side that attaches to the frame. The bolt is tightened to spec. I can grab the stabilizer and twist it back and forth.
Old 02-05-2016, 02:24 PM
scope103's Avatar
The end of the stabilizer is like a "ball joint," so it can be moved.
But not with just your hand. It should be much more rigid than that. I'd just replace it.
Old 02-05-2016, 02:44 PM
d-wood's Avatar
Thanks bro.
Samson3113
05-26-2016 03:11 PM
JaredL
02-14-2016 04:09 PM
kauaiaxel
02-03-2016 09:18 PM
shooter86314
11
02-01-2016 07:45 AM
Chris Parker
01-21-2016 09:04 AM
Quick Reply: Is it fine for steering stabilizer to wiggle on one end?
