Finally! Toytec 2 inch lift before and after pics
Old 02-06-2009, 02:06 PM
Yotapowa's Avatar
Got the 2 inch AAL and BJ spacer lift in my truck, heres some pics
Before:
After:
Old 02-06-2009, 02:09 PM
904_runner's Avatar
Arn't showing up here.
Old 02-06-2009, 02:20 PM
Yotapowa's Avatar
ah crap! I will see if i can fix it
Old 02-06-2009, 02:25 PM
Yotapowa's Avatar
fixed!
Old 02-06-2009, 02:32 PM
4banginRunner's Avatar
looks good
time for an alignment now
Old 02-06-2009, 02:34 PM
Yotapowa's Avatar
Yeah, I allready aligned it, It was sooo bad before.
Old 02-06-2009, 02:35 PM
Jay351's Avatar
Looks great! Time for some armor
Old 02-06-2009, 02:39 PM
Yotapowa's Avatar
Your right! I will take a pic of the rollbar and bumper chillin in my driveway and show you later!
Old 02-06-2009, 02:42 PM
Haha, I've been riding with my tires like this \ / for 6 months and 2000 miles, burnin through my extra tires and hoping my IFS grenades soon.
Old 02-06-2009, 03:38 PM
Yotapowa's Avatar
haha, I know what you mean. You going to SAS?
Old 02-06-2009, 03:45 PM
Yotapowa's Avatar
armors..
All I have to do is make them pretty, then I can get them mounted. I also am getting a proper tube bumper for the back and some rocker guards, then i will be set
Old 02-06-2009, 04:38 PM
Yessir, as soon as I can get my funding up lol
Old 02-07-2009, 01:46 AM
Yotapowa's Avatar
Right on, Im in the same boat. I may just buy a solid axle truck instead, I donno
Old 03-06-2010, 08:54 PM
Dmanflynn's Avatar
I dont mean to completely bring back a new thread to life over something simpler but it beats posting a new thread. Im thinking of purchasing the toytec 2"lift kit as well, I have a 5spd 4wd single cab 93 pickup. Will I need any kind of shifter extension, will there be any issue with my 4wd having to be dropped? And I know it would work with out this, but wouldnt it be better to get new torsion bars to cope with the new lift or is there any reduced/increased stress at all on them with this type of lift? I need to know everything to replace/upgrade to go from completely stock, to this kit. Oh, and my truck has manual lock outs as well.
Old 03-06-2010, 09:59 PM
mightymouse's Avatar
no to the shifter extension. You might need to drop the front diff if you cranks the torsion bars too much. You should only need to upgrade torsion bars if you have an after market bumper with a winch and might not even then. Since you have the lockout hubs you shouldn't need a diff drop.
Old 03-07-2010, 09:18 AM
Dmanflynn's Avatar
Ok, but for arguments sake, I do plan on putting a heavier winch bumper on, and I would like the t-bars to be as unstressed as possible. How would one go about deciding on a different t-bar? What I'm asking is, do you need stiffer ones for heavier loads, longer ones or what? I'm not real sure how they work to begin with other than a twist is applied to create tension.
Old 03-07-2010, 09:29 AM
yes they twist to create tension. Heavier load equals stiffer bars. Search around a lot of people run after market bumpers with winches and leave their torsion bars alone but many upgrade to a larger diameter bar to compensate for the weight. Check out sway away lots of guys run them here. I think they're around 25 or 26 mm bars. Not sure search a little for after market torsion bars and you should be able to pull up the info on it.
Flying91
45
04-11-2024 04:39 PM
88sasturbotoy
08-11-2015 01:56 AM
coffey50
07-28-2015 10:55 AM
Michael oaks
07-27-2015 11:47 AM
Yotoder865
07-09-2015 07:51 PM
Quick Reply: Finally! Toytec 2 inch lift before and after pics
