Finally! She starts every time!!
Old 02-02-2015, 03:54 PM
87-4runner's Avatar
I finally gave up the hard way and just fixed the problem. It would Not crank very randomly, but I could jump it, and it would crank everytime.
After rebuilding starter, rebuilding alternator, adding grounds, upgrading to bigger cables, Red Top Optima battery, and nearly 3 years of trying everything to get my truck to crank and all I had to do was this.
Old 02-02-2015, 03:59 PM
bswarm's Avatar
That's cheating! Did you check the ignition switch?
Old 02-02-2015, 05:19 PM
McGregor's Avatar
What is that?
Old 02-02-2015, 05:35 PM
bswarm's Avatar
It's a push to start switch.
Old 02-02-2015, 05:58 PM
McGregor's Avatar
Ah ok thanks. That's what I was thinking, but didn't want to guess.
Old 02-03-2015, 04:05 AM
wallytoo's Avatar
prior to installing the push-button, did you attempt to fix the toyota factory wiring flaw in the starting circuit, which contributes to a good percentage of the "no-crank" incidents?
wally
Old 02-03-2015, 05:36 AM
JasonYota's Avatar
Originally Posted by wallytoo
prior to installing the push-button, did you attempt to fix the toyota factory wiring flaw in the starting circuit, which contributes to a good percentage of the "no-crank" incidents? wally
X2.^^ My 4Runner has a push start, that will be fixed during my build.
Old 02-03-2015, 06:03 AM
bswarm's Avatar
Something else to check...
In the 1990's new car dealers were installing starter disable "Prolock Anti-Theft" units on all vehicles, wanting to charge about $100 more for it. If the vehicle buyer didn't want it the dealer would superglue the prolock key in the socket and break the head off, leaving the thing in place instead of removing it. Years later lots of people were chasing problems with starters when the problem was the prolock having a bad connection. It's usually mounted on the lower dash above the gas pedal and looks like an SD card reader.
Old 02-03-2015, 08:15 PM
RAD4Runner's Avatar
No you did not; you only masked the real problem, and now your truck has a push-button start like a Prius- J/K - LOL!
Where did you connect the switch? To the starter solenoid?
would Not crank very randomly, but I could jump it, and it would crank everytime. After rebuilding starter, rebuilding alternator, adding grounds, upgrading to bigger cables, Red Top Optima battery, and nearly 3 years of trying everything to get my truck to crank and all I had to do was this.
What other symptoms did you observe?
1) Did you hear the C.O.R. click behind the glove compartment but did not crank?
2) Where did you connect the switch? To the starter solenoid spade connector (here)?
3) And now it consistently cranks?
If yes to 1, 2, and 3, then your truck absolutely has the flawed wiring that Toyota DID and even documented, like Wallytoo mentions ^^. REAL fix, not band-aid, is on my sig.
serenity03k64
06-27-2015 07:59 AM
nrgetic99
7
06-27-2002 05:58 AM
jalaber
06-10-2002 06:28 AM
Quick Reply: Finally! She starts every time!!
