finally passed smog...but got problems
Old 05-19-2009, 04:47 PM
Ebell's Avatar
so today my 86 truck passed smog but they had to retard the hell out of the distributor to do it, after they did this I had absolutely no power. I will obviously change it back to what i had it before but im curious if this is usual for the older generations or maybe its a sign of something. I just changed oil, plugs, and even cleaned most of the throttle body. I am just a little confused on this
oh by the way its a 22re with about 200,000 miles on it.
Thanks
Old 05-19-2009, 05:24 PM
abecedarian's Avatar
Retarding the timing will usually lower NOx emissions. Given the mileage on the engine it's possible you have some pretty heavy carbon build-up in the chambers.
Can you post all of the test results? That might make it easier to figure out what's up.
Old 06-17-2009, 06:50 PM
nhughes's Avatar
I tested again today and passed with awesome numbers, But I did have my mixture knob at -15 and was reading AFR's at 15-17:1! But hey I'm ENVIROMENTALLY FRIENDLY!
Look at these numbers!
http://65.82.88.69/AZDrvTce/rdPage.a...orwarding=Form
jasonty
41
12-23-2018 01:00 PM
tj884Rdlx
08-28-2015 12:04 PM
Hamonacracker
07-17-2015 08:33 AM
HaydenConQueso
07-12-2015 05:22 PM
timmJ
07-07-2015 02:01 PM
Quick Reply: finally passed smog...but got problems
