finally got my sr5 gague cluster
Old 01-04-2011, 08:17 PM
mitgithens's Avatar
i got a sr5 cluster today out of a 1990 4runner v6 at a junkyard for 15 bucks
although i had to calibrate my tac it was pretty easy except for attaching the speedo cable
and i swapped it into my 90 ext cab with a 22re
glad to get rid of the giant tac
for the oil pressure switch, do i get a 4runner sr5 one? will it screw into my 22re?
Attached Thumbnails finally got my sr5 gague cluster-photo0067.jpeg   finally got my sr5 gague cluster-photo0068.jpeg
Old 01-04-2011, 08:44 PM
Blue 89 Runner's Avatar
Nice red X.... try again with pics !
Old 01-05-2011, 06:37 AM
kwnate's Avatar
Old 01-05-2011, 08:25 AM
yotaman90's Avatar
You might want to edit that pic kwnate......
Old 01-05-2011, 08:48 AM
kwnate's Avatar
Thanks, you might want to edit your sig.
Old 01-05-2011, 12:15 PM
yotaman90's Avatar
Eh, I haven't had any complaints yet. I figure it's different enough to not get flagged
Old 01-05-2011, 04:18 PM
snowbear's Avatar
You need to make sure you get the proper sender. There are two different senders and it depends on which manufacturers cluster you have. There is one thread here somewhere that explains it. Getting the wrong sender just means the gauge wont read correctly.
Yes it screws in the 22re.
Old 01-05-2011, 06:43 PM
BrianJE's Avatar
You just need the sender for a gauge. got mine here. http://www.rockauto.com/catalog/rafr...929468-2631791
Old 01-05-2011, 11:34 PM
myyota's Avatar
Go back and pull the oil sender from the truck you got the gauge cluster from, if it still has the engine in it.
Old 01-06-2011, 09:16 AM
mitgithens's Avatar
hope the pictures work now
^thats the problem the motor wasnt there, or else i would have grabbed it
and i looked at the other sr5 that they had and the motor was also gone
Old 01-06-2011, 12:06 PM
myyota's Avatar
You just need the sending unit for an SR5 truck with the gauge. Make sure you unplug the sending unit wire for the oil gauge until you get the right sending unit or you will ruin the oil gauge.
Old 01-06-2011, 05:42 PM
snowbear's Avatar
details on pressure senders....
https://www.yotatech.com/forums/f160...rified-220052/
malteserunner
Early Land Cruisers (Build-Up Section)
89
02-09-2018 06:59 AM
mussy01
12-13-2016 08:20 PM
gary4runner
09-24-2015 12:53 AM
teknovls
08-09-2015 12:37 AM
Esibnitsud
07-30-2015 08:21 PM
Quick Reply: finally got my sr5 gague cluster
