a few misc. problems
Old 01-29-2008, 09:21 PM
90inworks's Avatar
1st. My knock sensor is broken clear off. I know how to fix it. My question is will it better my mpg if i fix it?
2nd. my O2 sensor is bad should i just get one from the wrecking yard? and how bad does it kill my mpg being broken?
3rd. I went to take my shift nob off and it wont unscrew any more. instead my hole shifter arm unscrews kinda hard to explain but how can i fix that?
thanks
clint
Old 01-29-2008, 09:31 PM
Jay351's Avatar
1st- not sure, letting sombody else get this one..
2nd- Get a OEM replacment from www.sparkplugs.com for CHEAP!. Yes it can effect your mpg pretty heavily.
3rd- sounds like the glue holding the metal shifter in the rubbery part (top) of the shifter came loose. Remove the shifter, pull the shifter apart, apply some VERY strong glue or adhesive, put back together!
Old 01-29-2008, 09:39 PM
90inworks's Avatar
on that spark plugs.com i cant find o2 sensors
Old 01-29-2008, 09:48 PM
90inworks's Avatar
never mind i figured it out. how do i tell if it was a cali one or not?
and my timing chain and pvc vaulves to my knowledge have never been replaced shoud this be done? and will it run at a smoother idol? and get better mpg?
Old 01-30-2008, 03:53 AM
bigt's Avatar
cali one if you nee to e test your truck
Old 01-30-2008, 08:17 PM
90inworks's Avatar
how do i know if its the cali one though?
Old 01-30-2008, 08:26 PM
Jay351's Avatar
You will have a pre and a post cat o2 sensor.
If its a regular truck it will just have a pre-cat o2 sensor.
SubiKing
08-21-2021 03:57 AM
theking11863
03-19-2016 09:36 PM
Logz808
07-26-2015 07:09 AM
Jonny246
07-24-2015 12:37 PM
kyletbert
07-17-2015 11:39 AM
Quick Reply: a few misc. problems
