Last edit by: IB Advertising
Browse all: Engine Guides
- Toyota 4Runner 1984-1995 How to Change Engine Accessory Belts
Step by step instructions for do-it-yourself repairs
fan belt change help
ok, well i was driving up the summit yesterday and all of a sudden, the lights for the alt. came on and it started overheating. well i snapped the fan belt, and had to be towed home. i have a new belt, but i cant seem to figure out how to get past the first 2 belts to get it on. i searched, but there are no specific explanations for this. any help would be awesome. thanks!
ummm, you'll have to take the AC and PS belt off first... there's no other way around it, sorry to say
if it helps, here's some pics of the belt routing
thanks bleeder, i was afraid of that. ive been reading that you dont have to take those belts off so i was just curious
so which bolts do i need to remove in order to get the AC and PS belts off?
the belt was thrashed so i just cut it off but getting the new one on is what im doing
so what order do the belts go in. does it go a/c, PS then alt? just looked at my engine realized the middle belt was missing :headscratch: dont really know when or how that happened. question is, can i keep driving it, because it is my DD, or stop driving it and fix it. thanks yall
i already fixed the fan belt a while ago. just didnt want to start a new thread so i asked what the belt order is because im missing the middle one.
that tension bolt makes it much easier to set your belt tension...without one, you need a pry bar to get your tension pulley tight enough to keep the belt from screeching, esp starting cold
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
WellsR
12
07-31-2015 03:27 PM
dinks07
07-15-2015 05:34 PM
