Fan always kicks in when starting. Any way to stop it?
Old 01-20-2010, 08:29 PM
sundog kid's Avatar
I noticed that regardless of temp, my trucks rad fan always kicks in when I start it, and it runs for about 20 seconds.
Now, if the rads hot, I get that. but in minus 40 the last thing the rad needs is a blast of cold air against it.
Anyone else notice this? Anyoneknow how to fix it so it only kicks in at temp? Hopefully with out adding a manual switch?
Everything else on the truck works properly I should point out, no thermostat issues, no over heating, all is norm.
Thoughts?
Old 01-20-2010, 08:36 PM
BigBluePile's Avatar
If it's a clutch fan, then no.
Old 01-20-2010, 08:38 PM
sundog kid's Avatar
Im assumingit is, and thats why it kicks in every startup. If it were electric, you would think it was solely controlled by temp no?
Old 01-20-2010, 08:44 PM
Yuppers.
Old 01-20-2010, 08:46 PM
sundog kid's Avatar
Ok, so could it be the clutch? I mean, it turns off every time also, and kicks in when temps rise. Is it like this on every toy?
I know older big rigs are like this, but it seems so inefficent
Old 01-20-2010, 08:48 PM
toyota4x4907's Avatar
Mine does it, no matter the temp. All three of the my 22res I have owned over the past 5 years have done it, regardless of the temp. Just a fan-clutch thing.
Old 01-20-2010, 08:50 PM
fireman1559's Avatar
its just the nature of the beast all trucks do it my 2007 ranger does it. just about every clutch fan will do it
Yes. They've been around for years, even my '06 has one. If you are THAT worried about it you could put a piece of cardboard in front of the radiator to block off some of that cold air.
Old 01-20-2010, 09:01 PM
or just slap an efan and dont worry about it again
Old 01-20-2010, 09:04 PM
sundog kid's Avatar
Yeah, the thought was to go to an electric fan.
I know my question seems very newbish in nature, but Ive always driven imports with 'newer technology' if you will lol.
Fack. anyone put a good elec. fan kit in there pickup? links maybe?
Old 01-20-2010, 09:08 PM
you could go to a scrap yard i think guys use the taraus efan if im not mistaken you could search for it
Old 01-20-2010, 09:13 PM
I have a piece of cardboard in front of my radiator!! But not for this reason. -40f + 55mph does not help in the warm cabin air department. Cardboard in front of the radiator does help some though, especially on long trips
when its -40, its going to be pulling cold air regardless of cardboard when first starting. so really, it won't help.
Old 01-20-2010, 09:17 PM
sundog kid's Avatar
Yeah for long highway drives in weather under -25c, I usually put cardboard in front of the rad. That s a birth right in northern Alberta, and most likely in Alaska too I guess! lol.
I think I found a good kit, will post any updates if I go this way.
Old 01-20-2010, 09:22 PM
haha. yes. So many vehicles have cardboard in front of their radiator. I need to put a new, bigger piece in if it gets colder. We have only had -40F/C here once this winter so far, so its not too bad
Old 01-20-2010, 09:24 PM
sundog kid's Avatar
You know, oddly enough, we had what I think may be our only bad cold snap already, happened in December. 4 days of -55c. Normally its this time of year that gets that way, for a good week or two, but lately its been 5-10 degrees under freezing.
Gotta love 'global warming', or 'economic recession' or 'el nino' or whatever the hell you want to blame it on.
I prefer cattle farts.
Old 01-20-2010, 09:36 PM
Blue_petersen77's Avatar
Mine kicks on as soon as I turn the key to the on pos without even starting it. I've had no problems with it and it doesn't screw anything up so I don't see any issue.
94 runner 4x4 3.0
Old 01-20-2010, 09:38 PM
yeah we're averaging about -25C to -30C here so far.
I like just "normal Earth cooling-warming cycles"
Old 01-20-2010, 09:42 PM
sundog kid's Avatar
94 runner 4x4 3.0
and it wouldnt be an issue where you live. but when your trying to turn over an engine with 300 000 kms on it, in -50c, you dont want to be blowing cold air against the near-frozen rad
Old 01-20-2010, 09:48 PM
You are talking about the little one in front of the rad right?
In that case I'd probably just disconnect it and see what happens.
coryc85
09-09-2015 06:24 AM
RobotMoose
09-02-2015 05:53 AM
AkitaDog
07-27-2015 02:38 PM
jackiebrownia
07-20-2015 09:02 AM
wilbertd
07-06-2015 07:39 AM
Quick Reply: Fan always kicks in when starting. Any way to stop it?
