Failed emissions on a fresh motor? Please help
I had a feeling I was going to fail and It did. It smells really rich.
22re, 350 miles on full rebuild.
HC load 121 load standard 220 PASS
CO load 1.83 load standard 1.20 FAIL
HC idle 350 idle standard 220 FAIL
CO idle 3.17 idle standard 1.20 FAIL
The truck has:
New 02 sensor
New plugs, wires, cap, rotor
Fresh 15 mile old oil change
New air filter
R/R fuel injectors
New fuel filter
Timing at 5 btdc with dig. port shorted
The truck is not throwing any codes nor does it have any stored.
It runs awesome no misses or anything, just seems to be running rich.
Any thoughts? I'm going out to make sure we have all the vac lines run correctly.
Thanks!!!
The truck has:
New 02 sensor
New air filter
R/R fuel injectors
New fuel filter
Thanks!!!
Thanks for the suggestion but I would like to find out what the problem is and fix it.
I went through the vac lines and all looked good. I did find a clogged EGR vacuum modulator filter and a clogged vac line from the modulator to the BVSV. Got it all fixed up and working properly. I'm not too sure if these problems would relate the the failed emissions though. Anyone have any more suggestions?
I'm really confused as to why this stupid truck won't pass. Almost everything is new and it runs great. I'm even getting respectable gas mileage (around 20 mpg)
I talked to an emissions place and asked them if it looked like it could be caused by a worn cat and they said no. Anyone think that would be a possibility? It's got close to 180k miles on it as far as I can tell.
Not to be mister obvious, but:
If your engine is new, running great, not throwing codes and not shooting out tons of smoke. Have you replaced your cat?
I know it sounds stupid, but the cat is that thing that unless fully clogged can be weak and not doing anything and you wouldnt know it. Also, the process is the cat is a chemical one, uses heat to do it... most cats need a good 10-15 minutes to get really hot and start functioning.
I say this, becuase everything else seems to be fine. If your cat is bad, you will fail no matter what magic you do in the engine. is it an old cat? They go, 100k is the new legal limit they have to last. If your running a 22re, its an older yota meaning my bet is the cat probably died at around 50k.
Just saying. Replace or at least inspect it. You can shine the hell out of that engine, a bad cat...your GONNA fail.
If you only have 350 miles on the engine, the rings probably havn`t seated completely. I would put some more miles on the engine before trying to smog it. As for the cat, if it has that many miles on it i would definatly replace it, they do wear out.
Yea, the cat is definitely original. Looks like I'll be buying one here soon. Thanks for the suggestion.
Regarding getting it smogged so soon. I don't have any choice, the tags expire the end of this month. I figured it would be ok since it passed 6 months ago with a blown HG and low compression on one cylinder. Just barely, but it passed.
I cant speak for any particular one, but the nice thing is cats are regulated by law.. they must perform a SPECIFIC function.. so pretty much anything you buy will work. Obviously there are higher brands, etc. than others but unless you get one from some guy in a trench coat your gonna be fine.
also. while the cat will probably let you pass. You said it smelled rich. Unburnt fuel smell? it could be becuase of the cat, but im curious..on your engine the mixture is ecu controlled..so? Sure nothing up?
I would lean it a bit if it is rich, maybe have it checked.
I don't know for sure that it's running rich. The exhaust just has a really strong exhaust odor. With the gas mileage I'm getting 20mpg, I can't say it's running super rich.
I'm going out to pull the cat off now, I'll post a picture here in a few minutes.
Hmmm. The honeycomb looks like it's intact. It does look like on one side it collapsed inward toward the other end. What do you think? It looks pretty good to me(it's not black or burnt looking at all)
other side
other side
Exactly! Put some miles on it, seat those rings. Low compression can cause high CO. Put a new cat. on change the oil. You could check your coolant temp. sensor also. It could be causing the rich run.
Buy a stock cat, not an aftermarket high flow or some other ebay performance garbage. Fortunately OBD1 is a little more forgiving. Also Cats lend more to fail on the NOX, not CO.
